Turbo Timer Problem....
Results 1 to 7 of 7
This is a discussion on Turbo Timer Problem.... within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; K, heres my problem. I've had an Apexi TT for awhile but have been unable to arm the alarm while ...
    Registered User DEADPOOL's Avatar
    Dec 2002
    Boca Raton, FL
    K, heres my problem. I've had an Apexi TT for awhile but have been unable to arm the alarm while the car is running. Recently I found that there is a way to make it work. I cut the dark green wire with the black stripe, and the grey wire as well. Tested it out and it worked fine.
    I drove home, got out and set the alarm. Walked away......and a few moments later the alarm went off . I tried it again........alarm goes off. I turn the car off, and set the alarm and notice that the dash light is flashing the security light
    Any idea what went wrong?
    "Celebrate we will, for life is short but sweet for certain"-DMB
    Liquid - "yes sticky! hes a god now!"
    02 WRX now JDM V8 STI (too many mods for my own good)
    Registered User GIRex's Avatar
    Oct 2004
    Oregon
    try re-connecting each wire and try 1 at a time.
    Dec 2002
    Boca Raton, FL
    Quote Originally Posted by GIRex
    ???? why would I reconnect them??? It's weird, I just went to walgreens, and it took about 4min before the car set off the alarm on it's own. Really really weird.
    Dec 2002
    Boca Raton, FL
    Found the problem. It was the shock sensor being set to max sensitivity. Works great now.
    Registered User DenverWRX's Avatar
    Mar 2004
    Denver, CO
    I take it the shock sensor is on the Apexi TT?
    I find that mine is doing the exact same thing, only I have the Blitz FATT II. For some reason, the alarm will go off at random while the timer is counting down. Any ideas?
    2004 Subaru Impreza WRX, Java Black Pearl.
    Modifications
    Dec 2002
    Boca Raton, FL
    Quote Originally Posted by DenverWRX
    No, the shock sensor is part of the factory alarm. You need to remove the center console covering the ebrake assembly. Then you will see the black security box. On the box there is a lil black piece of tape and the words above it saying shock sensor etc. Remove the tap and adjust the setting. I put mine in the middle of the max and min setting.
    Mar 2004
    Denver, CO
    Awsome! I'll go try that right now. Thank ya' very much.
    Modifications
