looks good but damn are you hosting those pics on a 28.8 modem or what?
This is a discussion on Got Recaros installed in my WRX, finally! within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Already posted this on i-club, but though it may be useful info here... After 4 hours of grinding MY00 Impreza ...
useful info here...
After 4 hours of grinding MY00 Impreza brackets, they are in!
The rear seats are stock, but I plan to get matching
Recaro fabric and recover the rear seats and the door panel
inserts.
There is a chassis bump/ridge near the mounting hole
closest to the seat belt bracket. What I had to do is grind
off a triangle shaped piece off the square seat bracket to
clear the bump. Even with the grinding, it did not go down
far enough (the hole is slotted) so it sat 1/2" higher in that
corner. What I did to fix that was used a 1/2" spacer on the
other side of the bracket and a longer bolt to make the
rear of the seat sit level to the floor. Also, the seat belt
bracket will hit the center console, so I just had to bend
it back a little to clear. I'll get some better looking spacers
made, as I'm just using a big nut... but overall I'm pleased
with the fit.
Matt
'02 Sedan Black (MT)
LOL, feels like it... that's what I get for $1 a year hosting...Originally posted by thetoulman
At night it's pretty fast though.
Matt
Sweeeeet...did you do the install yourself, or did you get it done somewhere?
Fahd
Floats like a butterfly and stings like when I pee!
did you get an airbag malfunction light?
Deliberating enclaves of like-minded people are often a breeding ground for extreme movements - Cass Sunstein
Law for Small Businesses - The D. J. Marcus Law Firm
Yes, I installed them myself.
I am getting an airbag light, but as soon as my 3 ohm
resistors come in, that should be fixed.
Matt
They look really good! Good thing you had a lot of patience!
Speaking of patience, I think it's more like a 14.4, or less, modem.![]()
All those who believe in psychokinesis, raise my hand. - Steven Wright
Moderator, of the "Super" persuasion
What is the weight difference between the two stock seats, brackets, and hareware and the Recaros with your bracketing solution?
They look great by the way! Comfy?
I'm still up in the air with my JDM STi/Sparco/Recaro debate.
JDM STi's are in the lead though!
-Jim
mattjk -- is that your car in your avatar? If so, could you post a larger pic? Thanks![]()
Fahd
Yup, it's mine.Originally posted by WRXin'
I've attached a bigger pic.
SWEEEEET...you need to post a thread in the exterior and appearance forum, and title it MY BAD ASS SUBIE
. I was never a fan of the different color lip, but your car totally changed my mind. What lip is that anyways?
Fahd
Thank you!Originally posted by WRXin'
That is a Carbon Fiber replica of the STI Ver.1 lip.
Matt
Matt,
Since you seem to have missed it before:
-JimWhat is the weight difference between the two stock seats, brackets, and hareware and the Recaros with your bracketing solution?
OOPS, sorry. I didn't actually weigh them, but theOriginally posted by PlatinumWRX
Matt,
-Jim
Recaros feel a good 10lbs lighter each, even with the
brackets and sliders.
They are SOOO comfortable, I feel like falling asleep in there
sometimes. It's like being in the arms of a woman with big
boobies!![]()
Matt
Matt, if you ever have the seats out of the car again, weigh them for me, I think there is more than a 10 lb. difference! The stock seats are VERY HEAVY.
-Jim
