I'm having this problem now. I'll do the duct tape trick, but if I don't have to go ghetto I'd prefer not to. So I want to do the other way, but how do I get the collar off? Just force it out from underneath?
Steve
This is a discussion on how do i get the shift boot on my airleather? within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Originally Posted by WRX-games Okay, maybe I can help a bit here. There are two Momo air leather type knobs ...
I have the same allen key one... I will have to try this out.Originally Posted by WRX-games
thanks for the tip![]()
Just call me Clark Kent
Offical Body Guard for the Bugeye Mafia.
Steve
--2004 WRB WRX--
Still way too stock.
Originally posted by MidnightFLAT4
I like A/C for the sole reason that it makes the idle sound meaner.
the boot has to be pulled over the bottom metal piece of the knoc. The bottom of the knob is threaded and has the allen screws in it. Do not use the smooth aluminum covering piece that screws in, as the shift boot will not stay up, and most likely tear in the process. Push the shift boot over the bottom, it'll stay up due to the threads on the bottom of the knob. It'll look just like the one up in the picture.
i remember when i was installing mine, i tried the no collar trick but i didn't like it because the boot was too close to the knob and it was bothering me while shifting because i was touching the boot so i went with the "tape" trick. But recently i pulled off the tape, forced the knob all the way and screwed the allens so it's bit lower and the boot sits now on the metal collar that's part of the shifter![]()
Also, if you are too lazy to use the tape method, just wrap a rubber band around the shifter and slip the boot over that. It will be thick enough to hold the boot up.
On MY05, I don't have anything and my boot stays right up against my Airleather. Did they change boots?
2005 WRB Pearl WRX
RIP - 12/21/04 - 2004 Nissan Spec-V
