Component speaker location/position
Results 1 to 7 of 7
This is a discussion on Component speaker location/position within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; I'm wondering where people have mounted the tweaters for their aftermarket components. Right now mine are sitting on top of ...
    Registered User hamz01's Avatar
    Jul 2004
    Chicago, IL
    I'm wondering where people have mounted the tweaters for their aftermarket components. Right now mine are sitting on top of the dash on either side facing up. They are velcroed down and look nice. I was going to put them where the stock tweaters were, but I didn't think they'd fit. Also, I think rear seat passengers benifit more from this positioning. I'm facing them up because the high notes sounded a little too harsh and "in your face". Of course, now I have a 10-band equalizer installed in the dash, so I guess I could tune around this... would that be better? Anyone have other ideas and/or pics for location/position?
    Thanks
    Brandon
    '11 WRX 5-Door, Dark Gray Metallic
    ClubWRX.net Vendor
    Mar 2004
    Los Angeles
    They should fit.Stock location is very good, and shouldn't represent a problem from an installation, or sound, point of view. just make sure that the tweeter is sealed with foam tape of dynamat to the door, so that it does not resonate or loose sound behind the door. If it's too bright, try a 10ohm 10 watt resistor. less than $5 at Radioshack.
    Jul 2004
    Chicago, IL
    10 ohm 10 watt resistor? Is it an ohm per watt? And, will that change the overall resistance of the component set?
    Also, what do you mean "sealing" the tweater to the door with dynamat... do you mean dynamatting the door behind the tweeter? The lower half of each of my doors is dynamatted.
    Here's a pic of how the tweater sits, by the way:
    Brandon
    Registered User jimmy04wrx's Avatar
    Jul 2004
    San Jose, CA
    hows the sound imaging with the tweeter mounted like that? i know u can mess with it with your eq and deck to a certain extent, but having the highs bounce off the front window like that?
    lightly modded with a hint of audiophile
    Jul 2004
    San Jose, CA
    BYW try to get your tweeter and woofer at the kick panel, u can fab. one or go to a shop
    Jul 2004
    Chicago, IL
    What's the kick panel? I should put the woofer and the tweater there, next to each other?
    Brandon
    Jul 2004
    San Jose, CA
    check out the site
    http://www.crutchfield.com/S-fXdoF4y...rch=kick+panel
    or check out my buddy's accord that he won a sq comp with
    http://www.sounddomain.com/memberpage/151662/1
    he doesnt have the pioneer setup anymore, he joined the dark side with an alpine cda9833 and alpine pxah700, not to say anything about alpine cuz i gots my cda 7998
