Results 1 to 2 of 2
This is a discussion on Help with Knocklink within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Need some help with my knocklink install. I've read directions that say to torque the sensor down to 6-10 ft.lb., ...
    Aug 2004
    AZ
    Help with Knocklink
    Need some help with my knocklink install. I've read directions that say to torque the sensor down to 6-10 ft.lb., but that sounds too loose. To those that have installed/used a knocklink - what did you torque the sensor to?
    Reason I'm posting is that I've been tuned twice so far, the last time on a dyno and everything was great until the knocklink started showing knock in every gear. EGTs are nice and low, and AFR is great, so I'm wondering if I installed the KN wrong and it's giving false readings.
    Thanks for the help/.
    Registered User ryland's Avatar
    Apr 2002
    NY
    Just a guess, but if it says to torque it to 6-10 ft/lbs, then I would torque it to 6-10 ft/lbs
    2004 Black WRX Sedan
    Mods = yes
