what does this button do? - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 23 of 23
This is a discussion on what does this button do? within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Its a vestigial button...
    SMR
    SMR is offline
    Registered User SMR's Avatar
    May 2004
    Stamford, CT.
    Wow, just wow
    Jul 2004
    Quote Originally Posted by ej20fan
    It's used so you don't hit parked cars when swerving through dark turns. So in case you're stupid enough to park in a dark turn, I can see your running lights. Please use it when doing so. Anytime you park on a poorly lit street/turn you should turn them on. It's a lot cheaper and less embarrassing than having another car slam into yours.
    I speak from experience.....
    that'll buff right out!
    ClubWRX.net Vendor
    Mar 2004
    Los Angeles
    It did. Except that it cost aropund 3k to buff.
  6. #19
    Apr 2004
    Cincinnati
    I thought so too, but notice how his rpm's are just under 1k, meaning that the engine is running. Also, another hint is that no abs, or other lights are lit, as should be the case if the keys were simply in the on position.
    So why is the CEL on????
    He makes a good point
  7. #20
    Sep 2004
    Largo, FL (Pinellas County)
    Quote Originally Posted by Red*Eye
    Oh, yea don't leave it on or you'll run down your battery.
    IIRC, somebody on NASIOC said that they're designed to be left on all night without running down the battery. So I would assume that if your battery is in good condition it shouldn't hurt it all that much.
  8. #21
    ClubWRX.net Vendor
    Mar 2004
    Los Angeles
    That "If" is pretty important. It's kind of like saying that you could run C16 on 30 lbs of boost and not shred your gears. Not knocking on you, simply pointing out that every car, every battery, and every driver will be different, meaning that for some of us, drain time is measured in hours, not days. Either way, if your electrical, and battery are in good shape (buy a yellow top optima) you're right, the motor should turn fine in the morning, without having to look for jumper cables.
  9. #22
    Registered User LeonZ's Avatar
    Nov 2003
    Denver
    It's my car and CEL is on because I don't have the CEL fix installed yet on my rear O2 sensor.
    Leo -
    2004 WRX Sedan (Mommy's Little Monster)
    -=Team Blue Sedan=-
  10. #23
    ClubWRX.net Vendor
    Mar 2004
    Los Angeles
    Alright. I can finally sleep now. CEL's are my #1 annoyance. You should really take care of that as it's really cheap.
