im a gauge n00b, info please
Results 1 to 8 of 8
This is a discussion on im a gauge n00b, info please within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; I am getting ready to order the Omori 60mm WRX-look gauges.....EGT, boost, and oil pressure to be exact. It recommends ...
    Registered User yelWRXlow1's Avatar
    May 2004
    I am getting ready to order the Omori 60mm WRX-look gauges.....EGT, boost, and oil pressure to be exact. It recommends buying the GReddy sandwich adapter as well, to make install easier. How difficult is it to do these gauges? I have no experience at all, and a few of my friends arent too sure how to do it either. I have a blitz DTT that has a boost gauge reading.....will i need to disable the boost gauge for that to hook up the omori boost gauge? Any help, hints, or tips would be GREATLY appreciated.....dont wanna get in over my head, haha. Thanks
    <---------------------I dont have the sonic WRX anymore....decided it was time for an upgrade!
    Registered User criz's Avatar
    Jun 2004
    Langhorne, PA
    those Omari gauges are awesome!
    Registered User bluerex47's Avatar
    Jun 2004
    ohio/texas
    pertaining to the boost and blitz dtt, i think you can have both show boost. a friend has that setup, only with a stock boost gauge instead. both work fine. i just never understood why you need two boost gauges.
    as for installation, theres a couple threads on scoobymods that i've been looking at. it doesn't really look that bad.
    be sure to post pics when your done
    good luck
    - chris
    04 wrx, 04 corvette, 66 GTO
    ACT installed at 36k...new Gears at 44k...
    Registered User djrez4's Avatar
    Colorado
    I think the hardest part will be tapping the manifold for the EGT. I'm sitting on a similar setup right now. I need to pick up the greddy sandwich. That thing has two holes in it, right? One for temp and one for pressure?
    Deliberating enclaves of like-minded people are often a breeding ground for extreme movements - Cass Sunstein
    May 2004
    Dohhhhh! I dunno, hahahahahhahaha. Can somebody help?
    Jun 2004
    ohio/texas
    what is the greddy sandwich?
    as for egt though, its not hard, but a lot of work. i think the best spot is to tap the number 2 or 4 exhaust manifold (stock headers) tube. all you have to do is take off the manifold (header), drill hole, tap, insert sensor and put it all back on. make sure to get rid of all shavings and your done.
    as for oil pressure, dunno for sure. i think you can just put it in the drain plug.
    edit - this might help even though its on a non turbo rs
    - chris
    ClubWRX.net Vendor
    Mar 2004
    Los Angeles
    Greddy makes an adaptor that goes between the oil filter and the block that has adaptors for both Oil pressure and Oil temp. It's only like $60 or so, and can be installed with your next oil change for free if you've run the other wires.
    Sep 2004
    Largo, FL (Pinellas County)
    I bought the threaded plug for the rear oil gallery (under the intercooler) and stuck my temp sensor in there. I remember reading somewhere that the sandwich adapter reads the temp after it goes through the oil cooler, and that the oil gallery is a better indicator of actual oil temp inside the engine. Plus the sandwich adapter lowers the filter a little bit. My $0.02.
