Results 1 to 7 of 7
This is a discussion on audio suggestions within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Just got my '05 WRX sedan last week. Looking to upgrade. What would be some suggestions for component brands and ...
    Registered User jmoth79's Avatar
    Sep 2004
    Ithaca, NY
    audio suggestions
    What would be some suggestions for component brands and sizes,
    for someone who listens mostly to metal/hard rock. I'm looking
    for clarity. And I don't wanna spend more that a grand.
    thanks in advance.
    Registered User sportwagon's Avatar
    Nov 2002
    Marblehead, MA
    how much are you willing to spend, dude?
    jl
    -Sportwagon '02
    Nov 2002
    Marblehead, MA
    woops...
    missed the grand part!
    Good!
    keep in mind... you need to know wheter you want amplified speakers or run off of HU (I don't recommend), aftermarket HU (head unit) or use factory, how much space you want to give up in the trunk... If you decide on Subwoofers and amplified speakers, you are going to need to run 4 gauge wiring to the trunk (could get away with 8 gauge, I guess, depending on wattage of amplifiers, etc.) plus you'll need a distribution block (unless you go with a 5 channel amp, maybe)... I guess what I'm trying to get at is there is a ton of variables that need to be decided by you!
    -Sportwagon '02
    Nov 2002
    Marblehead, MA
    plan on....
    spending at least a hundred on wiring and terminals and other needed acessories if you are going to wire up amps! Less if you use the factory speaker wiring (another no no in my book, but saves $ and a TON of labor hours... I still remember how hard it was getting the speaker wires through the rubber grommet connections in the doors!)
    HU... if you get one... you can get a decent MP3 player for 200ish
    (MP3 single disc in dash has probably twice the capacity, in hours of play as your six disc changer... plus it will be easier to hook up amps with the pre-amp outputs found on mostly all aftermarket HUs)
    300ish total...
    spending now comes down to amps, sub, and speakers
    Heres what you should remember:
    upgraded speakers are going to make a night and day difference over the stock paper speakers, but since you like rock and metal... I'd go a little more than bottom of the barrell here! This is where the majority of "your music" is going to be heard... Do the speakers justice... with a nice 4-channel amp... and speaker wire (not factory)... you can always add bass later... and you'll have the wiring almost set up for adding a second amp if you run quality power and grounding wires!
    Whoah... speaking of wiring... RCA's are expensive! Well good ones are, and they are what carry the sound signal to your amps! add at least fifty-eighty for four channel RCAs and an even hundred for quality RCAs for four speakers and a Sub!
    Dynamat... adds character and quality to your sound... don't worry too much about it, although if you don't add a sub to your car right away... dynamat will enhance the bass coming from your speakers!
    -Sportwagon '02
    Sep 2004
    Ithaca, NY
    whaddya think...?
    are the best sounding component and or 3-ways under $200 a pair.
    4" rear and 6 1/2's front.
    thinking about:
    http://www.crutchfield.com/S-r2Ru7i39xVu/cgi-bin/ProdView.asp?s=0&c=10&g=400&I=108425I&o=p&a=1&cc=0 1&avf=Y&search=
    head unit: http://www.crutchfield.com/S-r2Ru7i39xVu/cgi-bin/ProdView.asp?s=0&c=3&g=62700&I=133C5410&o=m&a=0&cc =01&avf=N&search=
    Looking for a single 10" sub too.
    Nov 2002
    Marblehead, MA
    those links didn't work...
    I did notice it was crutchfield, though....
    Listen, crutchfield is a great site and they are a great dealer, but I'd consider purchasing from another online retailer, you'll save a ton of money! Research things on Crutchfield's site... possibly buy the wiring harness from them, but I would stay away from large purchases there! my 2cents
    6.5's fit in the front and rear (in my wagon at least) but you'll need 1 or 1.5" spacer rings for the front doors! Also, with separates, you'll have a factory tweeter mounting spot in the front doors, but you'll have to cut a hole in the door for the rear doors, I did with no problems, but you might not want to, I don't know!
    -Sportwagon '02
    ClubWRX.net Vendor
    Mar 2004
    Los Angeles
    Check out my post, click here , and call me/pm me. Even if you milk me for info like so many others , I'll still be glad to help any fellow Subaru owner.
    Claudiu Ene
    Sales Manager "Sound Waves"
    (818) 787-7166
