here you go...oakos automotive![]()
http://www.oakos.com/Merchant2/merch...egory_Code=400
This is a discussion on Gauges with the instrument cluster within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; I recall there being a gauge pod that sat on top of the instrument cluster that held 2 gauges. One ...
I recall there being a gauge pod that sat on top of the instrument cluster that held 2 gauges. One would sit bottom left and the other bottom right.
Anyone know of this?
-Brian
Twisty Monster - 335 ft/lb of torque @ 3600 rpm on a stock turbo. Is that possible? Yes it is.
- chris
04 wrx, 04 corvette, 66 GTO
ACT installed at 36k...new Gears at 44k...
Thanks!
Looks like 52mm though. I was hoping to fit the 60mm Defi BFs in there.![]()
-Brian
i have one im not using ill bring on saturday if you want to check it out.
Vanitas vanitatum...et omnia vanitas
Does it fit 52 or 60mm?
Bring it either way. I'd like to check it out.
-Brian
i have that one, though i dont know if theres a 60mm one brian. but i enjoy it.
Originally Posted by DTR rex
its a 52 but i dont see any reason why you couldnt dremel off the extra little bit. ill bring it though. if you want it cool, if not, cool.
i agree, i don't think there is a 60 mm setup, but it looks like you could trim the holes a little bit to fit the bigger gauge.
btw what gauges are you running? (both brand and type).
edit - oops. looks like gusto beat me to it![]()
- chris
Thanks guys.
Gusto bring it and I will check it. I think I may get suckered into purchasing the new red faced Defi BF gauges to match the STi gauges.
-Brian
bring it - if brian doesn't want it - I may take it (if it's v2 which does not crop the top of your speedo). someday I'm going to need to keep an eye on my EGTS...
-tp
The 202 Wagon
Bugeye Mafia "Silent But Deadly Ass-sasin"
"Just when I thought I was out... they pull me back in!"
