I have never seen one. You could probably make the autometer one work though.Originally Posted by Stealththx
This is a discussion on 60mm Instument Cluster Gauge Pod within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; I have been looking for a 60mm instrument cluster pod that will hold 2 60mm gauges similar to the cheap ...
I have been looking for a 60mm instrument cluster pod that will hold 2 60mm gauges similar to the cheap Autometer one but I can't find one anywhere! Does this product even exist? I thought I remember seeing one awhile ago but now I'm just not sure.
buy the 52 and dremel it out. 7+mm isnt alot to removeOriginally Posted by subieworx
Vanitas vanitatum...et omnia vanitas
No it's not, but the way the autometer bezel is designed 7mm would cut out the side of it. You would have to go back with some filler and smoth it over then repaint it.Originally Posted by gusto
the bezel on the gauges should cover the edge. take your time and i think it wouldnt be a problem.![]()
Vividracing.com sells the a-pillar pod for 2 or 3 60mm gauges. It comes painted and looks great!!!! I have one in my sti, u just remove the old a pillar drill 2 holes and screw in the new one.
