Results 1 to 7 of 7
This is a discussion on Rear view mirror install within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; I bought a used Auto dim Rear view mirror for my WRX but I can not figure out how to ...
    Registered User wrxboy02's Avatar
    Jun 2003
    Minnesota
    I bought a used Auto dim Rear view mirror for my WRX but I can not figure out how to get the old mirror off. It should snap off the glued on mounting plate but........? Can somone enlighten me?
    Registered User qoncept's Avatar
    Oct 2003
    Montgomery, AL
    Without running out and looking at it, I'd guess there's a screw keeping it from sliding off. And maybe a plastic cover hiding the screw.
    Jun 2003
    Minnesota
    No screws or covers
    Anyone no the answer to my question?
    Registered User Hank's Avatar
    May 2002
    Tallahassee, FL
    It's easy...
    Twist the entire mirror counter-clockwise and then it should come out. When you install the auto-dim one, reverse what you did to get the stock mirror out. Let me know if you have any other questions
    May 2002
    Tallahassee, FL
    Registered User BarbieJeep's Avatar
    Jun 2004
    Chandler, AZ
    Funny avatar wrxboy02
    2004 WRB Wagon R.I.P. (Officially a lemon)
    SAVE DARFUR! http://www.savedarfur.org/content
    NEVER let fear hold you back from something beautiful.
    Jun 2003
    Minnesota
    Thanks
    Hank, your the man.
    FYI: Thought I would break it if I twisted it too hard. You need to pry out the bottom just a bit with a screw driver and then twist it 90 degree's. It uses a tension spring to hold it in place.
