Results 1 to 15 of 19
This is a discussion on Latest status on dual gauge bezels? within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Does anyone have any idea on what's going on with Autometer and their dual gauge bezel? I want one, but ...
    Jan 2003
    Boston, MA
    Question Latest status on dual gauge bezels?
    Does anyone have any idea on what's going on with Autometer and their dual gauge bezel? I want one, but not with all the fitment and discoloration issues that I have heard about.
    If not the Autometer, are there any other options?
    How about a vendor fabricating one? I'd probably pay big $$$ for a nice one like the mythical silver prototype seen a while back.
    1995 Green Eclipse GSX AT
    2002 White Impreza WRX AT
    svc
    svc is offline
    I <3 Kelly Clarkson svc's Avatar
    Mar 2003
    Westminster, CO
    I ordered/installed one about a month ago, it fits great and hasn't discolored yet. Maybe they fixed the earlier problems? Get's two thumbs up from me
    sammAy!
    Registered User slowscooby's Avatar
    Aug 2004
    Winter Springs, FL
    yeah i was thinking about getting that myself. do you have any pics of it installed? also how easy was it to install? where did you run the wires?
    "Drift cant beat grip"- Nakazato
    svc
    svc is offline
    Mar 2003
    Westminster, CO
    Here's a night shot of both pods (triple dash/clock and dual bezel)
    sammAy!
    svc
    svc is offline
    Mar 2003
    Westminster, CO
    Closeup of the dash pod...i'll try and find a close up of the bezel
    sammAy!
    ClubWRX.net Vendor
    Mar 2004
    Los Angeles
    Which gauges are those??
    Please specify as they look awesome. I really like the blending witht the OEM colors. Who makes them, (Greddy?) and what do they read. I saw Boost and Voltage, not sure about the other ones. EGT, Oil Press, Oil Temp perhaps. Let me know.
    Registered User DRIVER's Avatar
    Baton Rouge, LA
    my guess is Omori
    Totally stock...yep uh huh :P
    svc
    svc is offline
    Mar 2003
    Westminster, CO
    Originally posted by DRIVER
    my guess is Omori
    Negatory (there's a rhyme for ya )
    They're 52 mm Greddy's. Boost reads in bar, oil pressure is in kg/cm^2, and the oil and EGT are in degrees C. The outside air temp gauge (left digital one in the bezel pod) is in degrees F...temp sensor is mounted on the intercooler (so I can see intake charge air temp, AND how much the IC sprayer lowers the temp )
    There you have it!
    www.worldoneperformance.com
    sammAy!
    Aug 2004
    Winter Springs, FL
    those look really good, nice setup. i was considering going with the greddy gauges....but i like the standard readings....im old school are the bezel gauges in the way at all?
    svc
    svc is offline
    Mar 2003
    Westminster, CO
    They're not in the way, except for the left one blocks the low-fuel light. Twice now it's gone unnoticed, and I roll into the gas station with a half gallon left.
    Otherwise, I love the positioning of both pods.
    sammAy!
    Registered User Racenut's Avatar
    Dec 2002
    California
    I've had mine for over a year now.. the color has not changed, and while originally I noted that it's not the same texture as the oem piece, it doesn't bother me at all now. The fit is fine.
    Is it OEM quality? No
    Is anyone but you ever going to notice? No
    Apr 2004
    Central NJ
    Does anyone know if there is one out there for 60mm gauges?
    Aug 2004
    Winter Springs, FL
    wow, nice pic racenut, i like that a lot. i wasnt too sure till i just saw that in your car. how did you run your wires though? i cant wait to get it now, i wanna get the omori gauges. I'm thinkin of getting boost and then im debating the second choice. i really want egt but its a pain to get a bung drilled and such. any suggestions on the second gauge?
    svc
    svc is offline
    Mar 2003
    Westminster, CO
    Oil temperature is good. It helped me realize I was low on coolant a few days ago, and it's good to know when your engine is warmed up
    sammAy!
    Dec 2002
    California
    Elecrical connections for the Omori gauges is at the clock wiring harness. The wires to the sending units just go through one of the rubber plugs in the firewall, I think it was up above the clutch pedal.
