Removing door panels..
Results 1 to 4 of 4
This is a discussion on Removing door panels.. within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; I've searched but haven't found much about this. Anybody have step by step instructions on removing the door panels?...
    Registered User verbal's Avatar
    Oct 2002
    Registered User WRX-games's Avatar
    Oct 2003
    Arvada, CO
    I know this has been discussed here before, but I can't find it either
    Front: take out the screw that is in armrest/cup thingie. Take out the window switch/lock assembly and disconnect it. There is another screw that you will see in that same location. Take it out. Now remove the trim around the latch handle (this is a little tricky, so take your time with it. Use a small flathead screw driver.)
    After that, you can pry of the door panel. Again, take your time and just pull it off from the edges. Once you have done that, just lift it up and off.
    I may have missed a step so anyone, feel free to add to this or correct me. It has been a while since I did the speakers in my front doors. The rear is a similar process and there is a little pop screw rivet that you have to take out. You will see it if you just look around the outside of the panel.
    James
    "Never criticize a man until you've walked a mile in his shoes. That way, if he doesn't like what you have to say, it'll be OK because you'll be a mile away and you'll have his shoes."
    Jun 2004
    Vanitas vanitatum...et omnia vanitas
    Registered User hybrid gti 2's Avatar
    Apr 2004
    lancaster
    i did not see any info so thought i'd add some. there are a few plastic screw things and pop fitings on the side as well the screw in the handle part where you close it. the rest is a pop off kind of thing. hope that helps.
    2002 wagon 83k miles
    perrin short ram, inlet & fmic, perrin / samco hoses and fuel rails, bosal dp. erz upp, borla catback, sti ra gears w/ stock 5th, act clutch & fly, vf30, AP, perrin end links, critical cooling kit, hks bov, perrin 4pot brakes, rota wheels, hid w/ levals
    Racenut3.0 - said
    "The worst thing about the AP is it did not come with any fairy dust. I wanna fly dammit!"
