Problem..... After using Air for a bit especially when rainy... but even with the sun shining.. The a/c fogs.. Condensation comes out of the vents..
I have had problems with the air and even had the evaporater completely freeze over... Suby then changed a temp sensor.. problem went away for a while.
Is this normal?? 03 WRX 10K miles
Last time they changed the temp sensor they routed the a/c overflow line the wrong way and water went all over the place into the car.. So I dont want to take it to Suby service unless I have to...
Recall still needs to be done too.
