STi Shifter trim - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 29 of 29
This is a discussion on STi Shifter trim within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; I just installed mine..i started with a razor blade and it was very difficult..a knife would make it a lot ...
    Registered User Weapon wrX's Avatar
    Oct 2002
    Thumbs up
    I just installed mine..i started with a razor blade and it was very difficult..a knife would make it a lot harder..a dremel tool ds work the best..i coulnt use the original platic boot holder for the shifter either...i had to take that off the leather boot and connect the leather boot to the bolts on the new trim..was yours like that Jedi??
    Banned jedimaster's Avatar
    Jun 2002
    No, I kept the plastic trim ring- it doesn't fit like stock, the bolts for the trim piece hold the plastic now. It's definitely a worthwhile mod, just for the "Ooh, Ahh" effect when you look at your shifter.
    Registered User tuca33's Avatar
    Aug 2002
    Brazil
    I am in the install process right now.
    So,should i keep the patic trim that the shift boot is attached too??
    how to keep it?
    Thanks
    Tuca
    SHould i start dremeling from the uppart or the downpart?
  6. #19
    Jun 2002
    Tuca- keep the plastic ring by attachin it with the bolts for the trim. And dremel from the top so you know you're not going too far- use a pencil to mark where you need to dremel- and go slowly- take off a little, then try to fit the trim- if it doesn't fit, take off a little more- you want the trim to fit nice and snug.
  7. #20
    Aug 2002
    Brazil
    I already made the trim,,
    now i want to know how to keep the plastic ring??
    because the bolts of the STI Shifter trim,,will not be too long for the fitting.
    and the ring plastic thingy that is attached to the boot is a little wide and tall.
    What mmore i have to dremel?
    Thanks
    Tuca
  8. #21
    Aug 2002
    Brazil
    Jedimaster,,it will not fit.
    The plastic ring that holds the shift boot is kind of strange,,and i dont think there is anyway of attaching the STI Shifter trim to somewhere.
    Where do the STI trim screws go into??
    they wont be fixed to anything.
    Tuca
  9. #22
    Oct 2002
    hey tuca,
    i just installed the STi trim as well...i had to take the boot off of the plastic and then i make holes in the boot that attached to the STi trim bolts..hope this helps...
  10. #23
    Jun 2002
    Yes Tuca- what he said ^^^^^^
  11. #24
    Aug 2002
    Brazil
    It took me the whole day..but finally i did it =)
    I drilled the holes without taking the leather boot from the plastic thingy,,i just drilled holes with leather and everything.
    Anyway,,the fit is difficult and it was boring.
    some of my bolts stayed disaligned ,,like not very straight.
    Thanks
    TUca
  12. #25
    Jun 2002
    Tuca- are you at least happy with the result? It sounds like you followed our advice.
  13. #26
    Aug 2002
    Brazil
    I am very happy and it looks awesome.
    but when i look very close,,i can notice the bolts are like,,aligned not ver correctly.
    is yours like that?
    Tuca
  14. #27
    Jun 2002
    Mine looks pretty straight- maybe just don't look so closely?
  15. #28
    Mar 2004
    NSW, Australia
    i need help on this
    please reply
    i cant get the sti trim screw on
    where do i screw it on to??? do i take the boot off the plastic ring and then what i do ??????????????
  16. #29
    Feb 2004
    El Cerrito, CA
    I just did this yesterday. I left the plastic thing on the boot. The trim screws were just long enough to go through the plastic trim, even with the lip pressed up against the sti trim.
