were do usually tap the gauges?
Results 1 to 15 of 15
This is a discussion on were do usually tap the gauges? within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; on the fuse box where is the best place to mount the wire for the gauges?...
    Registered User WRXout's Avatar
    Dec 2003
    Houston
    Fadi....
    • 04' WRX, Stage 4 with fmic R.I.P
    • 05' WRX STI, 325whp 346wtq @17psi
    MODS
    Quote Originally Posted by Trailboss
    Enough of the bloody titties show.
    Registered User SERacing's Avatar
    Feb 2003
    Staten Island, NY
    Re: were do usually tap the gauges?
    You can't dim them correctly then...on scoobymods it shows that you're supposed to go in some place by the radio.
    SIRacing.Net
    Originally posted by yermom
    heh, fairlady
    does not sound like a fast car, no wonder they changed the name for the US market
    ClubWRX.net Vendor
    Mar 2004
    Los Angeles
    do you wish to trigger with the headlights?? If so, most radio's have an orange/dimmer wire in their harness. tap into that and use a relay to trigger, as the output on that wire will be insufficient to light up your gauges. If no wire is present, then test in the fusebox or behind your gauges, repeat aforementioned process. Please make sure to use a relay as doing so will prevent overloading your electrical system.
    Dec 2003
    Houston
    the lights work but im trying to figure out why my egt gauge works but not fully? i know its the grounding but we tested it and its recieving voltage fine...the egt gauge wouldnt work wouldnt go over 3 this guy playd with it but its not fully working it goes up to 5 but when i press the brakes it clunks down and when i put the bliners on it twitches
    he changed the egt bung that connects to the exhaust and that didnt work then we tried to switch the gauges and the ones he had wouldnt work its weird...maybe i need a new battery? :/
    my oil pressure is electrical and it works just fine doesnt twitch when i press the brakes or the blinkers
    Fadi....
    MODS
    Registered User Rancid's Avatar
    Jun 2002
    www.awdpirates.net
    I used the clock to tap my gauges because the wires are labeled!!
    www.awdpirates.net
    Banned sarcasmo's Avatar
    Jun 2003
    Seattle, WA
    I tapped off of the radio ignition wire for the power to the gauges and the radio dimmer wire for the illumination. I used vampire taps and never had a problem.
    I don't recommend using the clock harnes as the it will cause your illumination to be backward - remember that the clock dims when you turn on your headlights.
    Dec 2003
    Houston
    the light is working fines and my oil press works fine but im not getting a correct reading from me egt
    Fadi....
    MODS
    Jun 2003
    Seattle, WA
    Try to make sure none of the wires from the EGT probe are touching any metal on the car. The probe uses a very small electric current and any little thing could mess with your readings. If it isn't that I would say that either your power or ground connections need to be checked and/or relocated. Unfortunately, there is no cure-all solution for a lot of car electrical problems.
    Dec 2003
    Houston
    can aluminum piping cause that?
    Fadi....
    MODS
    Jun 2003
    Seattle, WA
    Aluminum piping should only cause problems if it is making contact with a bare wire. If you were closer I'd take a look at it for you, but I doubt you want to make the trip to Seattle. Is there anyone in your area that is more comfortable pulling apart the dash and following the wires? I'm sure someone would do it for some pizza and/or beer.
    Jun 2002
    www.awdpirates.net
    Uh...this is not true. The clock dims when it recieves a certain voltage from the dimmer thingy. This same voltage is what signals to light the gauges up. Mine are wired to the clock, and work perfectly.
    www.awdpirates.net
    Jun 2003
    Seattle, WA
    Perhaps your gauges are wired differently or your clock works differently. The stock clock does dim when you turn on the headlights. This is to prevent the clock from blinding you in a dark car. Most modern car clocks behave this way. I will note, however, that even while the clock is dimmed you can further control the brightness with the dimmer switch.
    This is how my clock works:
    Car on headlights off: clock is bright and light output can be modified by dimmer switch
    Car on headlights on: clock brightness is automatically decreased and light output can still be controlled by the dimmer switch - however - the clock will not get as bright with the lights on as it will with them off.
    Try going into a dark garage and ligting up your gauges, but not your lights. Then turn on the headlights and watch the gauges. If they work like mine did (when I had them wired to the clock) they should automatically dim.
    Jun 2002
    www.awdpirates.net
    Thats how the clock works.
    My gauges are not backlit when I don't have my lights on. When I turn my lights on, the clock dims, but my gauges backlights turn on, just like they should. This is how the circuit works: when the headlights are turned on, a 12 volt signal is sent to the clock. Even though a greater voltage is sent, the clock dims (probably due to resistors in some kind of loop). This same 12 volt signal is what powers the gaauges and tells them to turn on the backlight.
    www.awdpirates.net
    Jun 2003
    Seattle, WA
    huh - I totally believe you. I did the same thing with my gauges, but found that they dimmed when I turned on the headlights. Perhaps my crappy Autometers were wired differently.
    I promise that this is what happened. I, however, could be the exception.
    Dec 2003
    Houston
    hehe i dunno it actully climbed to 7 celsious today
    but still acts funny
    Fadi....
    MODS
