Blitz DTT Help
Results 1 to 15 of 15
This is a discussion on Blitz DTT Help within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; I installed my Blitz DTT using the harness. Right now everything is hooked up and i'm just testing stuff out. ...
    Jun 2003
    San Diego
    Blitz DTT Help
    I installed my Blitz DTT using the harness. Right now everything is hooked up and i'm just testing stuff out. So I started my car up, the unit powers on fine and i can cycle through all the settings, but when i turn my car off, the blitz turns off as well...so it wont run the car after i turn the car off and take the keys out.
    Any ideas..?
    Thanks
    Official ClubWRX arms dealer SOUTHPAW's Avatar
    Feb 2003
    CT
    Its not hooked up right. I had the same problem w/ mine... You need to ground it or something... I cant remember.
    *1969 Camaro - Kickin' It Old School
    PICS & MODS
    *2005 Corvette C6 - A few APS bolt-ons
    PICS & MODS <- Built by XX Tuning
    *2003 Subaru WRX - 332 AWHP - SOLD
    Jun 2003
    San Diego
    Well I used the blitz harness, and grounded both ground wires. I checked all the connections and everything is connected securely...I tried using different settings auto and manual timer, but nothing will keep the car running once I turn the car off...
    So I'm not sure what's wrong..
    Registered User wrxinfx's Avatar
    Mar 2004
    house
    This problem occurs with most Blitz tt users..... Search this forum and there will be at least 3 with the same problem as you. One thing that you will have to re inspect is the connection of the e brake wire to make sure that it has a secure connection. Most people tap into this with a wire tap and sometimes there is no bare wire connection. I spliced to gaurantee a secure connection, and when I did, the unit stayed on instead of knocking off automatically. Try it and if it doesn't work.. come back and the others can help you out
    Jun 2003
    San Diego
    I didn't hook up the ebrake wire yet. I didn't know that was necessary for the turbo timer function to work...
    Mar 2004
    house
    yup, its a safety feature. That way no one can steal your car when you leave. As soon as the e brake is disengaged or put down, it completes a circuit... sending a signal to the blitz unit telling it to shut down... thats the simple explanation. could get technical on ya but kinda hard to follow. Connect the e brake wire. Its essential to the proper operation of the unit. good luck
    Jun 2003
    San Diego
    yeah i know what the ebrake wire does, i just thought it was optional, and didn't need to be connected...
    what is the best way to connect it? just splice into it and put some electrical tape around it?
    Mar 2004
    house
    yup, simple but effective.. if not you could get those wire taps if you don't like cutting factory wiring.
    Jun 2003
    San Diego
    I'd rather not cut any factory wiring if i dont have to...
    What are wire taps, and how do they work?
    Feb 2003
    CT
    No, no, no, it's not just the e-brake! Mine works w/o the e-brake up. As a matter of fact i took the keys out while driving yesterday and set the timer for 9 mins!!! Look mom, no keys! I do feel sorry for the guy who tries to steal my car though,... because as soon as you try and turn the wheel, it's lock up city.....scared the $hit out of me!
    PICS & MODS
    Mar 2004
    house
    unwritten law.. here ya go.. http://www.partsexpress.com/pe/pshow...number=082-140
    Southpaw. Did you just ground the e-brake wire to the chassis? I figured this would work also, but isn't it safer to have the e brake tapped as I would rather have would be thieves not going anywhere than to have them drive away and have the steering lock up and trash my precious car.
    Mar 2004
    house
    this one is easier to use...
    Jun 2003
    San Diego
    thanks for the info. how do the wire taps actually work? sry, i'm a newb at electronics...
    and as far as the ebrake wire needing to be connected for the turbo timer function to work, can anyone actually confirm this? because i dont want to hook it up right now if i dont have to. i dont plan on letting the turbo timer run a long time and I'll be in range to lock and arm the car when it turns off.
    i just want to know why its not working correctly. i've checked the connections..not much to screw up..since i used the harness, everything looks good there..i'm stumped..
    Mar 2004
    house
    There's no bad things that happen when you hook up the e-brake wire. Only bad thing that can happen is that you don't and someone drives off with your car. Tap just opens up and clips over other wire. The hole you see at the larger end is where the e brake wire goes in. Snap shut and there you go. Not too hard. It splices into the wire for ya. All you need to do is crimp a spade plug to your tt e brake wire and plug it right in. Takes less than 1 minute. Although it'll take you 5 minutes to take off the center console. My total time to hook up my Blitz with harness was 20 minutes with the hardest part trying to unhook the stock ignition harness. The easiest was tapping the wire.
    Mar 2004
    house
    And if you don't like to splice wires and crimp spades.. get this and just insert both wires.... clamp shut and you should be in business..>>>>>>>>>>>>
