Metric Gauges?
Results 1 to 5 of 5
This is a discussion on Metric Gauges? within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Can we use JDM metric gauges in our cars? I wonder if they'd be a simple no hassle install. Does ...
    Banned JDMSubaru's Avatar
    Aug 2003
    Irvine, CA
    Metric Gauges?
    Can we use JDM metric gauges in our cars? I wonder if they'd be a simple no hassle install. Does anybody know?
    Registered User wrxinfx's Avatar
    Mar 2004
    house
    What kind of gauges are you installing? Should be compatible as far as wiring and vacuum lines ( for boost gauges ). Wiring is usually universal for most gauges and the only difference is the reading of the units. metric vs. standard. Im a noob at doing this and its pretty easy so it should be the same for you. Good luck
    Aug 2003
    Irvine, CA
    thanks, I mean the speedo and tachometer one (main cluster)
    Mar 2004
    house
    If I remember right, Nabisco had an install on on a cluster install. Or was it scoobymods? Maybe it was a thread on Nabisco that went to scoobymods... oh well . They did a detailed thing on putting on the JDM impreza gauge cluster to an american Rex. Don't know much else as I didn't read further.
    Registered User SweetTurboWhine's Avatar
    Jan 2004
    Reading, PA
    JDM will work fine, just get used to km/h.
    and heres the v8 sti gauge intsall
    http://www.rspeed.org/howto/sticluster.php
    i just read that you have an 05, so that installation guide would NOT apply to you, but i dont have enough knowledge about the 05's yet to tell you anything differently
    as far as i know, USDM and JDM STi gauges should be swappable directly. if you want JDM sti gauges on your sti, unplug the neg on the battery, take off the trim around the cluster, unscrew the cluster off the dash, remove harnesses, take out USDM, put in JDM plug in all wires, screw to dash and put trim back on, reinstall neg on battery and enjoy
    woooo
