Turbo Timer + Alarm...How?
Results 1 to 7 of 7
This is a discussion on Turbo Timer + Alarm...How? within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; I installed my turbo timer but now i got to fix it so i can use the alram as well.. ...
    Registered User Jack's Avatar
    Mar 2003
    North New Jersey, School at Susquehanna University in Pennsylvania (Rt 287, Rt 78, Rt 22, Rt 80)
    http://www.scoobymods.com/forums/sho...=&threadid=228
    I was following these directions, it sa splice the accy wire? and cut the grey wire...i dont get it...
    Splice the accy wire but to what? and what does the aCCY wire look like under there, thanks!!
    -My name is Tom not Jack
    Check profile for mods
    "I wanted to put a bullet between the eyes of every panda that wouldn't screw to save its species" Fight Club
    Registered User SERacing's Avatar
    Feb 2003
    Staten Island, NY
    Step 1: After installing your turbo timer with the under dash panel off, locate the black relay box on top of the fuse panel. Unbolt 1 (10mm) bolt and cut the Green with Black wire. Tape both ends of the wire and reinstall relay box. Reassemble under dash panel.
    Step 2: Remove the panel in front of the armrest by pulling up on the cup holder. Disconnect the power mirror terminal. Locate the wiring terminal for the security system. Cut the Grey Wire. Tape both ends. Reattach power mirror terminal and cup holder panel. Enjoy!
    - fastwrx.com
    Hope this helps sort of.
    SIRacing.Net
    Originally posted by yermom
    heh, fairlady
    does not sound like a fast car, no wonder they changed the name for the US market
    Mar 2003
    - fastwrx.com
    Ill try it out tomrrow,
    Thanks!
    Tom
    Registered User ProblemChildWRX's Avatar
    Apr 2004
    San Diego, CA
    If you car is a WRX '04 the gray wire that runs along the side of the passenger seat is actually a light green wire. Splice the purple wire to the light green wire. On my car there is no security system where the e-brake is located at.
    "If at first you don't succeed, then skydiving is not for you."
    Mar 2003
    Well i did it and it works!! YAY! .
    I didnt do the purple wire to the ebrake cause couldnt seem to find the pink wire underneth the carpet.
    Only thing i dont like is that when I set the alarm with my turbo timer on the alarm will go off like 2 seconds later cause my exhaust is toooooo loud. I dont want to lower the alarm cause my car was already stolen once...GRRR!
    Nov 2004
    Install new remote with Turbo timer?
    Hi
    I have a turbo timer intalled in my car. I lost my remote to the keyless entry, so I bought a new that I have to install.
    My question is: Do I have to disconnect the turbo timer to install the the new remote?
    And if so, do I have to reprogram the turbo timer if I disconnect it?
    Please HELP ME!!!
    Thanks!
    Daniel
    Apr 2004
    San Diego, CA
    Quote Originally Posted by WRXDaniel
    Hi
    Please HELP ME!!!
    Thanks!
    Daniel
    I don't see why the alarm would have anything to do with the turbo timer.
