Boost gauge help!
Results 1 to 5 of 5
This is a discussion on Boost gauge help! within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; I am going to get some autometer boost gauge or some other mechanical boost gauge. Anyone can tell me I ...
    Registered User AUTO228's Avatar
    May 2004
    QUEENS
    Question Boost gauge help!
    I am going to get some autometer boost gauge or some other mechanical boost gauge. Anyone can tell me I can hook up as same as the factory boost gauge( connect wire from the back of the radio and run to hose to the Bov with "T" fitting????
    Registered User wake2snow5's Avatar
    Jan 2004
    Ellensburg, WA
    You can use the same wire from the radio. I modified the boost gauge hose after seeing this thread. It works like a charm.
    http://www.scoobymods.com/forums/sho...ight=autometer
    May 2004
    QUEENS
    I can't get in that web site. Can you tell me what you modify on the hose? What is the difference?
    Banned dark_rex's Avatar
    Aug 2001
    The Hub
    depending on which guage you choose, you may not have to do any modification. he probably just adjusted the diameter of the hose using a connector.
    the stock guage has a plug for the harness on the back fo the stereo, so you won't be able to do that. you'll need to splice a wire.
    tapping power is easy. the yellow green wire to the clock is "on" power from the ignition. tap that, and black to ground.
    searching will help you out immensely.
    dR
    Jan 2004
    Ellensburg, WA
    Here is basically what I did:
    Essentially, you will need a length of standard 1/8" vacuum line to plumb from your vacuum source to your boost gauge. You will need about 6 inches of 3/8" line, 2 very small hose clamps that fit around the 3/8" line, and NAPA's Hose Connector part no. 715-1815.
    Here is a picture of the finished product. You should now have very quick response from your boost gauge, and a lot more faith in it to boot.
