Results 1 to 15 of 22
This is a discussion on Aftermarket speakers that are 100% bolt in within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Are there any? Im not talking about wiring, just mounting. I dont want to make spacers if possible- (although i ...
    Registered User BoostedBoxer's Avatar
    Mar 2003
    NOR*Cal
    Are there any? Im not talking about wiring, just mounting. I dont want to make spacers if possible- (although i can).
    Also- should i get an amp? I dont want any subs, just CLEAN sound.
    My Car is 100% STOCK!
    Pics
    Originally posted by platano
    At 14???
    shoot , I'd hit it at current age, on roof of the car, with cousin driving , neighbor and town priest in the back seat, and that kid from "N.Korea" riding shotgun.
    Aug 2003
    Norway, Europe
    Re: Aftermarket speakers that are 100% bolt in
    Yes getting an amp would normally give better sound, but if you have no plan of getting a sub im not sure what I would do maybe loose the amp to get easy wireing and small weight.
    Better amp = better sound (if the speekers are good tough..)
    But how about clean sound with a small sub?? You don't need to install a 2x12" subs in a ugly box..
    I will personally install dual 8" or 10" subs with a nice and small amp and aftermarked speekers..
    Silver -02 Impreza WRX
    "sitting in the corner in Rick Roll timeout" chanwahyaoh's Avatar
    Mar 2004
    Detroit
    I would get an aftermarket HU first (if you don't have one already) if you want to clean up the sound. That would help the most.
    Other than that, I don't think there's really many direct bolt-on speaker options. If you don't want to make them, the spacers from iaperformance are pretty nice.
    Turtles are nature's suction cups.
    .____
    ||J || R.I.P.
    ||__||
    |/__\|
    Registered User ProblemChildWRX's Avatar
    Apr 2004
    San Diego, CA
    I have the spacers for iaperformance and it made my life a lot easier. It also provides you with a bigger and better choice of speakers, since the spacers allow fitment for 6.5 speakers. IMOP, I would get the spacers, they are worth it.
    "If at first you don't succeed, then skydiving is not for you."
    Mar 2003
    NOR*Cal
    I am for sure going to get a head unit first. Do any of you have a link to the spacers?
    Pics
    At 14???
    Apr 2004
    San Diego, CA
    Here is the link:
    https://w109.webminders.com/iaperfor...log_subaru.asp
    I got the WRX Thick Complete Kit (6.5 front/5.25 rear). It was easy to install and it comes with all the hardware needed.
    Mar 2002
    Tokyo, Japan
    When you start adding things like 2 10" subs, think of all the weight that you're adding into your car. It's like holding an entire person in there once you're done with your whole set up.
    "I don't think he knows how to give up. His mind and machine are racing as one." -Takahashi Ryosuke
    Mar 2003
    NOR*Cal
    I dont want any subs AT ALL
    Pics
    At 14???
    Mar 2004
    Detroit
    quick note on the spacers....depending on the speakers/spacers you get, you may have to trim out some of the plastic on the inside of the speaker grille in the door panel.
    It may not be a bad idea to do it anyway, as I hear that it tends to rattle (have not experienced it personally though).
    .____
    ||J || R.I.P.
    ||__||
    |/__\|
    Mar 2002
    Tokyo, Japan
    Thank god
    Registered User ssamurai26's Avatar
    Aug 2003
    Japan
    I think you can get aftermarket 4" speakers that will go into the rear doors without modification, but to my knowledge there are no 5.25" speakers that will go in the front doors without spacers.
    "I am Bullrock, and I have lots and lots of powers"
    へおひってしりつぼめ "There is no use scruntching up your buttocks after a fart"
    Nov 2003
    Sheesh, I don't understand you guys. My sub + box + amp = ~60 lbs, and thats heavy stuff too! How many 60 lb friends do you have? Maybe you are racing people all the time, so you are willing to suffer through crappy music to gain an extra 0.05 seconds in your 1/4 mile time!
    Seriously.
    You can't 1/2 a$$ this stuff. Good speakers are nice, but you will also want to add a couple pounds of dynamat or raamat to your doors to deaden the sound, Subaru uses paper-thin sheetmetal. An amp is nice, but you really wont get much bass without at least an 8" driver. If you don't like subs, get one that you can remove in a couple of minutes. I can remove my sub and amp in about 3 minutes with a phillups screwdriver. (weighs about 5 ounces).
    If you want drop in speakers, 5 1/4 inch components that are shallow will fit the front, (at least with minimal grinding) and 4" 2-ways will fit in the back. Don't spend too much money on the speakers, because without sound deadening and amplification, it's kind of silly. Check out www.crutchfield.com and you can compare specs (like depth) on any speakers they have. That said, for about $800 you could build a simple system with a small sub that would be 100% better than a deck and stock-sized speakers. You could also look into the Infinity Basslink. Its light, compact, and surprisingly good for a little more than $200. I'm sure you could engineer a way to remove it for your 1/4 mile blasts.
    edit: changed 1st paragraph to hide my exasperation.
    Former car: 2002 Cobb/Scoobysport stage 2 WRX sedan
    New ride: ???
    Mar 2003
    NOR*Cal
    Seriously.
    Good advice- thanks for they input. DO you guys think the stock "upgraded" sub will do me just fine? I really DO NOT need alot of bass (or even want it).
    Pics
    At 14???
    Nov 2003
    I liked the stock sub for what it was. Just enough to make your music sound normal. I think the stock sub + upgraded speakers might not be a bad way to go.
    New ride: ???
    Jul 2003
    KC, MO
    I can open my trunk, take off my bungee cords and take out my sub in about 30 seconds. Have you ever heard the difference between subb'd suby with the stock. it is like a completely different system. I recommend you get one. it will do much more for your car than new speakers will.
    04 WRX Black no options!
    Helix up/downpipe, HKS catback & Bov, autometer gauges and MRT shortshifter, Bronze Rota SDRs, UTEC, tein SS coilovers, HKS type1 turbo timer, 6000K HIDs, JDM spec C front/rear lips, 20% tint
    to be installed: Mines Spoiler
