Subaru Keyless remote programming instructions
Results 1 to 6 of 6
This is a discussion on Subaru Keyless remote programming instructions within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; This may be a repost, but I just got these instructions for reprograming WRX "round remotes" when I purchased a ...
    Administrator
    May 2003
    This may be a repost, but I just got these instructions for reprograming WRX "round remotes" when I purchased a used one off of ebay. Hopefully they can be helpful.
    Round Remote Transmitter Programming Instructions
    1. Disarm the security system (if so equipped).
    2. Open the driver's door and sit in the driver's seat.
    3. Close the driver's door. 4. Place the ignition key in the ignition switch and cycle the switch from "LOCK" to "ON" ten times within 15 seconds. Be sure to stop at the "LOCK" position and leave the key in the ignition when you are done. The horn will sound once to indicate that you are in transmitter programming mode.
    5. You must finish the next steps within 45 seconds of the horn honking.
    1. Open the driver's door.
    2. Close the driver's door.
    3. Press and release any button on the transmitter. The horn will sound two times to indicate that the transmitter has been programmed.
    6. After programming your remote, remove the key from the ignition switch. The horn will sound three times to indicate the system is now out of programming mode. Ensure your remotes work properly at this time
    You may program up to four remotes at any one time. If you lose a remote, program the other four times to clear the code for the lost remote until you can replace it. Do not program your remotes with other Subarus in the vicinity- you may be unknowingly programming someone else's remote for your vehicle!
    Administrator
    May 2003
    These are the "square remote" instructions
    Square Remote Transmitter Programming Instructions
    2. Turn the ignition to the "ON" position
    3. Locate the programming button. It is located near the OBD-II diagnostic connector above where the driver's feet would be while seated. Press and hold in the programming button for 15 seconds. The door locks will cycle three times, indicating that the system is ready to accept a new remote transmitter. Do not release the programming button during the next steps.
    4. Press the "LOCK" button on the new remote. The door locks will cycle once.
    5. Repeat step 4 for any additional remotes.
    6. Exit programming mode by releasing the programming button and turning the ignition off. Ensure your remotes work properly at this time.
    You may program up to four remotes at any one time. If you lose a remote, program the other four times to clear the code for the lost remote until you can replace it. Do not program your remotes with other Subarus in the vicinity- you may be unknowingly programming someone else's remote for your vechicle!
    Jan 2011
    Oregon
    2002 Impreza
    My horn does not work. Can i still program a keyless entry remote?
    Registered User Daddy_Digital's Avatar
    Feb 2011
    Mesa, AZ
    Quote Originally Posted by Trainrex View Post
    fir some reason after i got in the car, and locked the doors manually and did the 10x on and off...unlocked the doors, opened the driver door, the car honked, pressed the clicker, the car was programmed. it didnt work with simply just opening and closing the driver door. locking the doors too helped.
    Registered User chelseypb's Avatar
    May 2015
    Western PA
    This did not work for me, and I'm not sure why lol (yes I checked the battery). I followed the instructions exactly and no beep after cycling the key or when I press a button after opening & closing the door. I have an 06 WRX with the factory security system.
    Nov 2016
    will a teardrop shape keyfob (brand new) that says its for 2005 and newer ... work for my 2004 wrx???? i dont like the squareish one.. not to mention, i lost said squareish one
