Boost Gauge Install
Results 1 to 2 of 2
This is a discussion on Boost Gauge Install within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; I just recently purchased a Faze boost gauge for cheap () at Autozone ( I think that's the start of ...
    Feb 2003
    Madras, OR
    Angry Boost Gauge Install
    I just recently purchased a Faze boost gauge for cheap ($60) at Autozone ( I think that's the start of all problems right there). I take the BOV line with a 1/4x1/4x1/8 T-fitting, no kinks in the vacuum line, ran it up the A-pillar and into the back of the gauge with the supplies brass fitting and ferrel. I hope I didn't buy a crap gauge, but whenever the car is running it says I have 20 psi vacuum and at WOT I have 4-5 psi of boost. This is crap...I have no clue what's the matter. It does sound like there is a small leak at the back of the gauge, but no matter how many time I try to retighten the supplied fitting it doesn't go away; is this small vacuum sound normal? What should I do? Also the only T-fitting I could find goes 1/4-1/8 and the stem is 1/4...will this impede air and mess something up? Thanks guys!
    tan
    tan is offline
    Thinking Man's Engine tan's Avatar
    Dec 2001
    Wharton, NJ
    when the car is running...it should be in vacuum.
    The boost problem...it could be a defective gauge....or a leak at the gauge...is the fitting in the back of the gauge tight?
    Damn..$60 for a mechanical boost gauge...sounds kinda expensive.
