Results 1 to 4 of 4
This is a discussion on Compustar Alarm Horn Output within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; I recently had the 2WSS Compustar alarm put in my car. The only problem is they didn't hook up the ...
    Registered User Stealththx's Avatar
    Feb 2004
    Channahon, Illinois
    I recently had the 2WSS Compustar alarm put in my car. The only problem is they didn't hook up the horn output because the installer said it would just honk all the time and wouldn't go on and off when the alarm is going off. But, befire this I had the stock upgraded alarm and that's all it did was honk the horn off an on. Is there a way to make the siren go off and the horn to honk? Also, do you know what wire I have to find if there is a way to do this?
    Registered User pjdwrx's Avatar
    Nov 2003
    Milton, WA
    You might try Compustar directly -
    Technical Support Contact Information
    Phone: (206) 957-3780
    E-mail: support@compustar.org
    Cool as the other side of the pillow.
    Registered User netZ's Avatar
    Dec 2002
    the installer sounds lazy, they could have easily hooked up the compustar's horn honk output to a 12 volt relay and a flasher. it would pulse out to your stock horns. the stock keyless entry has a built in 'flasher' to honk your horns.
    netZ
    Feb 2004
    Channahon, Illinois
    Where can I get a 12V relay and a flasher? Can I pick these up at Radioshack? Also, do you know what color the horn wire is in the car?
