Air bag replacement?
Results 1 to 10 of 10
This is a discussion on Air bag replacement? within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; I'm finally finished rebuilding my WRX from the totaled state and now i have to get it inspected. My problem ...
    Registered User MNBodyMan's Avatar
    Sep 2003
    Minnesota
    I'm finally finished rebuilding my WRX from the totaled state and now i have to get it inspected. My problem is both front air bags went off the the crash. I have purcashed a new drivers side one but that is it so far. Do i have to replace the control module underneath the console no matter what? Is there a way to test if it is bad? I know i will have to replace the front bumper sensors because they were the ones that set it off. Is there a way to totally get rid of the air bag system light without fixing them for now? I'm kinda running out of money on this project and don't really want the air bags in general. Thanks for the help in advance.
    Administrator
    May 2003
    Re: Air bag replacement?
    Anytime airbags go off the airbag ecu is toast. the air bag system needs to be functioning to go through the salvage inspection. When you turn on the ignition the airbag lamp will blink a few times. If they don't see that you will fail. Also check with your state laws if you can use used air bag parts. Some won't let you. Did the seat belts blow off too? If so, you will have to fix them also.
    Sep 2003
    Minnesota
    The seat belts seem to work fine, is there anything i should check on them?
    Administrator
    May 2003
    Nope, if they pull out of their retractors and go back in they are fine. The WRX has force-limiting seat belts. When you get in a frontal collision they basically explode inside like airbags and pull you back into the seat. When they are blown they wont pull out or retract.
    Sep 2003
    Minnesota
    Good deal. Now i just gotta find some deals on airbags. Thanks again.
    Administrator
    May 2003
    Anytime. Just make sure you can use used bags in your state. Also keep the receipts an vin#'s on ALL used parts you put on the vehicle, they will want to see them. If you have any other questions about this feel free to ask, I've done it many times.
    Registered User ebr0t's Avatar
    Aug 2002
    U of Central Florida (Orlando)
    It would be totally pimp if you had 2 blowup dolls as the air bags.
    Quote Originally Posted by DTR rex
    Peter North > *
    Registered User BlueSubie02's Avatar
    Jun 2003
    South FL
    [quagmire] alllriiightt, giggity giggity [/quagmire]
    Sep 2003
    Minnesota
    Wow! Then you wouldn't even be mad when you got in an accident, you would be gettin some action right then and there!
    Nov 2003
    This solution is easy. Your check engine light goes on for about 2 seconds when you start up, then goes off. Wire up the airbag light to the check engine wire, viola. Looks like everything is working fine. You can also use the seatbelt wire too, that usually goes away after a certain amount of time. Screw airbags.
    Former car: 2002 Cobb/Scoobysport stage 2 WRX sedan
    New ride: ???
