Results 1 to 7 of 7
This is a discussion on sub power within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; I want 2 10: jl w06 subs. Im trying to find the best amp to use. they are 400w RMS. ...
    Registered User Vektra's Avatar
    May 2004
    Columbus, GA
    sub power
    I want 2 10: jl w06 subs. Im trying to find the best amp to use. they are 400w RMS. the amp Im looking at now is a audiobahn a8002t 400x2 at 2ohm 800x1 at 4ohm. correct me if im wrong but could I wire the 2 jl's at 4ohm and bridge this amp and get about 400watts to each speaker or am I missing something? and what other kind of amps do you suggest
    "sitting in the corner in Rick Roll timeout" chanwahyaoh's Avatar
    Mar 2004
    Detroit
    You can call up JL Audio and see what they'd recommend. I've talked to their tech support a couple of times, and they're really cool/informal. Just tell them you already bought the subs, and see what amp they'd recommend.
    954-443-1100
    9am - 5:30pm eastern
    Turtles are nature's suction cups.
    .____
    ||J || R.I.P.
    ||__||
    |/__\|
    May 2003
    Wisconsin
    Just get a JL 1000/1 or something if you have the cash.
    - F r a n z
    Bucky with teh lime powah!
    Registered User FutureWRX15's Avatar
    Aug 2002
    Roswell Georgia
    I think he has 2 subs. Needs a 2 channel amp.
    Future Wrx Owner
    89 Bronco II (R.I.P.)
    68 Cadillac Coupe DeVille
    May 2004
    Columbus, GA
    the 1000/1 is where I may go but its a little more than I wanted to spend. mono will work with 2 speakers just have to do the wiring right
    Aug 2002
    Roswell Georgia
    True.
    I was planning on getting that amp, over the summer when i get my car. Not WRX though i can't afford it
    Future Wrx Owner
    Registered User ProblemChildWRX's Avatar
    Apr 2004
    San Diego, CA
    Try this web page from crutchfield. It shows different wiring diagrams for the impendance of the subs and amps.
    http://www.crutchfieldadvisor.com/le...rs_wiring.html
