Results 1 to 15 of 15
This is a discussion on pic of blue rocker switch within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; today i installed a rocker switch to activate a solenoid that switches between the stock bc and mbc. took a ...
    Registered User gifty74's Avatar
    Mar 2002
    Lancaster, PA
    today i installed a rocker switch to activate a solenoid that switches between the stock bc and mbc. took a while to decide, ended up putting it in the blank switch panel right by the mirror controls between the shifter and e-brake. check out the pic below. i thought it came out pretty good...
    Registered User Nexus6's Avatar
    Jun 2002
    O.C., Ca
    Did you install that yourself? Its a clean install...
    La Fee Verte
    Subaru 2002 Impreza WRX Sedan
    Mar 2002
    Lancaster, PA
    yeah, dremeled out the majority of it, then finished with razor blade. i oversized it a little too much, doesn't show everything in the pic. not perfect, but pretty decent for a first attempt.
    Registered User tekan's Avatar
    Jun 2002
    Atlanta, GA
    I had a switch identical to that one and the components inside kind of shifted after I switched it a couple of times. The led inside gets disconnected somewhat often. :-/ So if you find it quits glowing, check the led.
    Moderator Penguinking's Avatar
    Nov 2001
    Houston, TX / Athens, GA -at the same time!
    i have that same switch, but mine's placed in the spot near the cruise control button.
    and mine looks really crappy too - i didnt have a dremel at the time so i used a coping saw to make the hole for the switch - so the thing is really scratched and the switch is off centre lol
    mine is used for turning the abs on and off
    Silver 911
    WRX's older brother
    Oct 2001
    Tristates
    Thumbs up
    Excellant installation
    What mods, dude this baby is stock
    2002 Platinum Silver 5spd sedan.
    Registered User Bask Oner's Avatar
    Jun 2002
    Chicago, IL
    Not only is it a clean installation, but the whole idea behind it is great. Have you described how the solenoid and MBC is set up anywhere, or are you holding off to sell the plans?
    Matt
    WRX-less, now RSX-y!!!
    Mar 2002
    Lancaster, PA
    great! glad to see others are interested in it too. i can say it has been working great for me and takes any worry out when on longer commutes and when the misses is driving. here's a link to the original thread . if you have any more questions feel free to PM or email me. i'd be glad to help you out. lateron.
    Nov 2001
    plans r fo free
    dawes devices markets a fairly cheap package, and you can make your own for cheaper - its a realy cool idea but i just don't have the $$$ to throw down on a solenoid rite now
    Silver 911
    WRX's older brother
    Mar 2002
    Tokyo, Japan
    looks like it came with the car..awesome job. How long did it take start to finish?
    "I don't think he knows how to give up. His mind and machine are racing as one." -Takahashi Ryosuke
    Mar 2002
    Lancaster, PA
    realistically it took ME about 2 hours, with tapping into the cig lighter wires and all of that. also had to route a wire up through the firewall to the solenoid. trimming the plastic piece that the switch rests in takes time. you just keep trimming a little at a time.
    Registered User cnoff's Avatar
    Mar 2002
    Denver
    I have the same setup except mine is next to the foglight switch like Penguinking's. Another really easy way to do a clean install is to get a switch with a round back and drill a hole slightly smaller than the switch back. Then just force it into the hole. My biggest complaint is that I have a reddish-orange switch and, when its on, my whole car glows like I have a neon interior at night. As soon as I fine a "softer" colored switch, I am going to switch it.
    2002 Platinum Silver Rex
    Mar 2002
    Lancaster, PA
    i agree, the switches with the round base are much easier. i was going to put up where you guys did, just thought i'd try something a little different. both places are great i think.
    Mar 2002
    East Stroudsburg, PA
    Painless Performance
    A suggestion. Check out http://www.painlessperformance.com/ . They've got a few things that I'm going to buy when I get my crap together a bit more.
    First, they've got aftermarket fuse panels. So, you can add as many additional links as you want.
    secondly, they've got some hella cool switches that are advertised to fit into most OEM switch-blanks. I've never used them, but I am going to try them out the next time I need to hook something electrical up :-)
    Moderating U! KurleeDaddeeWRX's Avatar
    Mar 2002
    San Jose, CA
    I used the same location, little bit bigger switch, but mine is RED. It controls my on/off switch for my amp in the trunk. I just need a fricking digital camera and I can take photos at MY leisure.
    Kurlee Daddee
    (THE ORIGINAL)
