omori boost guage w/ fluttering needle
Results 1 to 6 of 6
This is a discussion on omori boost guage w/ fluttering needle within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Just replaced my stock column mount with an omori 45mm mech boost gauge. I followed the directions on J-spec's website, ...
    Aug 2002
    Unhappy omori boost guage w/ fluttering needle
    I followed the directions on J-spec's website, but I notice that the needle flutters like a banchee when idling at a stop, or even under load frequently ( mostly @ PT). Anyone with any ideas on where to start checking?
    edit: after running around a bit at lunch, it occurs while in neutral (stop lights, etc) and some what under different throttle posistions.
    Sedona Red Wagon, Nicely Tinted
    Thule Bike RackS
    Registered User IDAFC21's Avatar
    May 2004
    Avondale, AZ
    hmm...not really sure what it could be. if you havent already, id just suggest going over your vaccum line and make sure there arnt any leaks in it
    Where did you get the Omori guage from? Ive been wanting to swap out my stock boost gauge w/ an omori as well
    Registered User FASICZKA's Avatar
    Mar 2003
    Orland Park, Illinois
    my omori boost gauge also flutters a lot, but i noticed that it starts fluttering on inclines and uneven streets it still reads boost correctly
    2002 WRB 4EAT WRX
    TXS turboback exhaust, Eibach springs, grounding mod, Perrin Short ram
  5. #4
    Banned dark_rex's Avatar
    Aug 2001
    The Hub
    i was thinking about replacing my oe guage w/ the omori 45mm to match my egt.
    should i reconsider? is this common?
    do you think it's still accurate?
    i've never heard of that before... i'd guess that it's defective..
    dR
  6. #5
    Registered User Lt. Boom Stick's Avatar
    Feb 2003
    This Island Earth
    dR, you're defective.
    PLZ send all questions on Omori Boost Gauges to Dark Rex. PM at least 3-4 times to make sure it goes though.
  7. #6
    Aug 2002
    I wouldn't reconsider yet. I may have eyeballed a poor connection in my hoses from when I replaced my pvc valve(same day as gauge) so when I try to fix it, I'll let you know.
    Coinsidentally, I noticed that when idling at a light, if I pinch the hose a pit, the fluttering stops. Let me check my connections first to be sure.....
    Thule Bike RackS
