quick quick amp wire help
Results 1 to 7 of 7
This is a discussion on quick quick amp wire help within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; I wired my amp and had an emergency while I was doing all of it and had the power wire ...
    Registered User Woody182's Avatar
    Mar 2004
    Chicago, IL
    I wired my amp and had an emergency while I was doing all of it and had the power wire from my battery hit against the metal in my trunk and it blew the fuse on the wiring kit.
    My wiring kit is a Rockford Fosgate, the fuse is in a plastic piece that I can screw a left and right side off but still can't get to the fuse.
    If this doesn't make sense I can try and find a digital camera to show it tomorrow.
    Thanks for the help.
    Mar 2004
    Chicago, IL
    I think this is pretty similar to what I have.
    Moderating U! KurleeDaddeeWRX's Avatar
    Mar 2002
    San Jose, CA
    Unscrew one side of the cap and get it out with a set of insulated handle needle nose pliers.
    Mar 2004
    Chicago, IL
    Thanks for the help
    I got it out, the fuse says "conquer" on one side and "AUE 40" on the other
    Is this something I can get from a normal hardware store? Or do I need to go to a car audio place?
    Mar 2004
    Chicago, IL
    After some more "research" are AUE and AGU the same type of fuses?
    Mar 2002
    San Jose, CA
    Originally posted by Woody182
    Thanks for the help
    I would say, go to a car audio place that sells car audio stuff to get yourself a replacement fuse.
    Mar 2004
    Chicago, IL
    I went to a car audio place, showed it to them and they came out a minute later with a fuse, $3 later, problem solved.
    Thanks a bunch
