installing amp this weekend, last minute questions
Results 1 to 8 of 8
This is a discussion on installing amp this weekend, last minute questions within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; ok, i'm installing my amp this weekend and ahve some last minute questions. 1. where in the trunk could i ...
    Oct 2003
    MN
    1. where in the trunk could i ground the amp? i looked under the carpet and saw soem bolts, can i ground to those?
    2. what level do i set the LEVEL input sensitivity to so that i could match the stock HU?
    3. i want to install a switch so that i could turn my amp off while still having music in the car on. do i connect the remote wire coming for the HU into the "power" on the switch? and the remote wire coming from the amp into the "load" on the switch?
    thanks
    Registered User power091999's Avatar
    Jul 2003
    To tell you the truth I did the following
    1. There is a bolt at the top dead center of the trunk. I used that for my ground.
    2. Don't know
    3. Just put a switch off the remote wire to the amp. You will still get sound out of your speakers, and shut off your amp.
    Hope that helped.
    BTW If your running your stock deck, I ran my speaker wire off the rear speaker. It takes some time but works great. Hits really hard.
    Registered User 04blkWRX's Avatar
    Jul 2003
    NNJ
    1. Any bolt that goes into the metal frame of the car is fine.
    2. If you are using line level inputs then I think you set the sensitivity to "1" if you are using speaker level inputs then you have to play with it to get the volume you want. Since you mentioned matching the stock system I guess you'll have to fiddle with it until it sounds good.
    3. Switch the 12v turn-on lead. I don't quite understand your power/load terminology, but that's what you would do. DON'T switch the power supply from the battery unless you want to buy a high amp switch.
    06 S40 T5 AWD
    Previous: 2004 WRX
    05 CBR600F4i
    Oct 2003
    MN
    i jus took out the radio and the wiring harness isn't labeled too well. i cant read the labels on the wires so now i dont kno which ones to cut into.
    which wire is the remote, i've read around that its blue, but the 03 model has 2 blue ones. and which wires for my LOC?
    Registered User platano's Avatar
    Feb 2003
    Miami
    1. Any bolt that goes into the car (metal) should work. However, make sure you clear the paint from the area. Bare metal is a better contact. Just sand a bit in the area around the hole. If you want to get fancy, use some of the goop they use for the battery so that it doesnt rust.
    2. Easiest way is to play it by hear. Play some of the stuff you listen too all the time. set it low, and start setting it higher as needed. if it starts to clip, then you want to set it lower than that and never go past that point. You want to get the highest volume without distortion. Play it by ear.
    3. Not sure about the question, You're using the stock HU right? What is the amp driving, just subs or all the speakers?
    Here's my thoughts if the above is the case.
    There should be a "remote" wire from your amp. When there is no power to it, the amp should remain off, even if the 12v wire is still connected. This is used so that when you shut off your radio, the amp goes off also.
    If you're using the stock HU I don't think you get a remote wire. In that case, your amp should have the following leads, 12vdc, ground, remote/power switch, speaker in/outs, rcas.
    The remote and 12v need to both have power in order for the amp to be on.
    Out of your stock HU, I would use the Front Left and FrontRightchannels for the door speakers in the front. And use the RearLeft and RearRight as your inputs to feed your amps. That way you could control/tweak the volume in the bassbox with the fader/balance controls.
    If you wanted to completely shut off the amp, I'd throw a regular, radio shack switch in series with your remote lead circuit.
    Quote Originally Posted by zoophagy
    Happy Birthday. May all your birthday dreams come true except for the one were I come over to your house, and you timidly ask me if I have ever kissed another guy before, and it ends up some weird poo porn movie.
    Oct 2003
    MN
    thanks a lot, that helped me a lot
    Feb 2003
    Miami
    I just gave you a general idea, so I forgot to mention, make sure you protect your stuff with fuses also. You rather burn a $1.00 than $$hundreds$$ on an amp.
    May 2003
    Wisconsin
    Or thousands if you burn up your car from having no fuses.
    - F r a n z
    Bucky with teh lime powah!
