Page 3 of 9 FirstFirst 123456789 LastLast
Results 31 to 45 of 125
This is a discussion on My dash/console mod within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; i should have read before i replied before lol... so you can take the green film off, it just takes ...
  1. #31
    Registered User VSGTS14's Avatar
    Apr 2004
    Milford, NJ
    so you can take the green film off, it just takes time..hmmmm...good..cause i'm going to do that.
    FP Green STi
  2. #32
    Registered User Web Foot STi's Avatar
    Jun 2003
    Portland, OR
    If you remove the cup holder you can pull the HVAC bezel with your fingers. One screw. I did the head unit install and the red change at the same time. I didn't use condoms though, unsafe sax?, and used a red Sharpie. It matches the dash and looks good almost a year later.
    Cones don't count at Hillclimbs.
  3. #33
    gfx
    gfx is offline
    Registered User gfx's Avatar
    May 2003
    Pittsburgh, PA
    Hmm.. that's smart. Any pics? If the condoms fall off or anything.. I'll have to try that
    2003 5MT WRB WRX Sedan
    Cobb stage 2.5 w/ VF30, Stoptech BBK, JDM STI front/rear seats, Mattjk LCD setup, JDM headlights w/ McColluch 6000k HIDs, GReddy EVO, 17x8" Gold Rota Torques, Eibach Pro-kit
    http://www.cardomain.com/id/gfxwrx
    My car shots taken with my Canon 300D dSLR
  4. #34
    Jun 2003
    Portland, OR
    Not that I'm smart. Very old post about the pen last year...
  5. #35
    Apr 2004
    Milford, NJ
    any pics of the red sharpie? i wanna see it.
    FP Green STi
  6. #36
    Jun 2003
    Portland, OR
    Sorry, I'm retro and don't own a camera, or cell phone for that matter...
    You pull off the green condoms and coat the bulb with ink. The original post must have been on Nabisco. I don't go there very often now. They ticked off a bunch of STi owners last fall...
    For all the world the pen does look like the condoms.
  7. #37
    Registered User WiCkeDrEx's Avatar
    Aug 2003
    VietNam
    for the cluster. do i buy 8 of these 74 bulb? http://autolumination.com/74.htm
    it does not seems like the condoms people were talking about. looks more like an actual bulb. also, do i buy the first row 74 bulb or the second row?
    13.7 at 98.74 MPH / Stock TD04 & No EM
  8. #38
    Feb 2004
    I did my HVAC blue the other day and they turned out so dark... are there LEDs I can buy or and trick to make then brighter?
    thanks
    New 2004 Subaru Impreza TS Sedan (canada only)
  9. #39
    Apr 2004
    Milford, NJ
    the more expensive ones.
    FP Green STi
  10. #40
    Apr 2004
    Milford, NJ
    thanks
    yes there are...
    you have to trim them to make them fit...
    seems that they are bright..
    i used red transparent paint on the stock bulbs and
    FP Green STi
  11. #41
    Feb 2004
    Originally posted by VSGTS14
    yes there are...
    what kind of LEDs should i get? size, type, where?
  12. #42
    Apr 2004
    Milford, NJ
    go here
    http://www.i-club.com/forums/showthr...5&pagenumber=1
    the only thing is that scraping the green film off will make them brighter....but you have to without taking the needles off and with this plastic thing around them...probably a little tough, but you can get it...it's better than messing the needles up
    FP Green STi
  13. #43
    Feb 2004
    i read in the othe forum use #74 blubs in for the gauges. he use 8 #74 blubs on his gauges but his car is a auto.
    is it also 8 #74 blubs for a 5 speed?
    thanks
  14. #44
    Registered User GetawayInBouldr's Avatar
    Feb 2004
    A Whales Va-jay-jay
    Ok, so I've taken out my gauge cluster and I can get the clear plastic cover and inner bezel off, but I can't get to the back of the gauge face plate to scrape the green film off. When I take the white housing off the back of the gauges, I'm stuck with the circuit board in my way. What do I do? Is there a way to get the circuit board off without damaging the cluster?
    ~ Silver Wagon Club ~
  15. #45
    Apr 2004
    Milford, NJ
    the circuit board is held on by the back of the needles motor...
    all you have to do is make pull a good amount gently on the fuel/temp side first to loosen it...then do the middle, then the other side..till they are loose..
    i was afraid, but was careful and it'll be fine.
    FP Green STi
