Removing the Backseat
Results 1 to 4 of 4
This is a discussion on Removing the Backseat within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Does anyone have any instructions on how to take the backseat of an 02 rex out? The reason I ask ...
    Registered User Stealththx's Avatar
    Feb 2004
    Channahon, Illinois
    Does anyone have any instructions on how to take the backseat of an 02 rex out? The reason I ask is I have to take out all of the trunk trim and I'm making an amp rack. Thanks for the help.
    Registered User power091999's Avatar
    Jul 2003
    There are 2 bolts holding the front down. Take those out and the (butt portion) will slide right out. As for the (back part) I don't know. Hope that helps a little bit.
    cnk
    cnk is offline
    NJ
    2 bolts on the lower footwell area. Remove the bottom cushion. Then there are 3-4 more bolts for the rear seatback. Lift up and the seat comes out.
    Calvin
    cnk
    cnk is offline
    NJ
    Almost forgot. . make sure you open the trunk passthrough as it will prevent you from removing the seatback if you don't.
    Calvin
