Results 1 to 3 of 3
This is a discussion on Mounting pods for Omoris within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Sorry if someone has covered this already. But I'm kinda stuck on deciding which pods/stands to use with 52mm Omoris ...
    Registered User wrxinfx's Avatar
    Mar 2004
    house
    Sorry if someone has covered this already. But I'm kinda stuck on deciding which pods/stands to use with 52mm Omoris that are coming in for a steering mount application. Autometer has one for the 2 1/16" gauges which is a pod. But will it accomodate an electrical gauge like the Omori I will be getting? HKS and Greddy has mounting bands that'll fit but will it look funny with the back exposed? And if you guys have these does the hks and greddy stick out too high. Any insight would help. Thanks
    Registered User Rojorex's Avatar
    Mar 2004
    Tampa area, FL
    I assume you mean you'll be mounting them on the steering column? Anyway, I mounted a 52mm Greddy elec boost in an Autometer cup (2 1/16"). Everything fit great and looks really nice.
    Autometer also makes a replacement dash bezel to mount two gauges... not sure if you knew about that.
    Check out the STICKY and top of this forum (Gauge Mounting options) for more ideas.
    Registered User Racenut's Avatar
    Dec 2002
    California
    That's what I used and it works good. Initially I thought the quality could use some work, but once it's installed, you really don't notice it much and forget about it soon.
