Results 1 to 7 of 7
This is a discussion on Odd clank sound within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Dunno where to post this but since Im sitting inside my car when I hear it this will have to ...
    Registered User pityr's Avatar
    Oct 2002
    Beaverton OR
    Odd clank sound
    Dunno where to post this but since Im sitting inside my car when I hear it this will have to do.
    at low speeds (near crawl) I hear this clanking sound coming from the front kickpanel/inner fender. Has anyone heard this? Any ideas what it could be?
    The sound is a quieter version of a cable banging against a flag pole in the wind.
    - Peter
    No one will truely be free until nerd persecution ends.
    Registered User SERacing's Avatar
    Feb 2003
    Staten Island, NY
    I have a clicking noise that happens when I start out from a stop (just starting to get the car rolling) no one knew what it was Hopefully I can get some suggestions too.
    SIRacing.Net
    Originally posted by yermom
    heh, fairlady
    does not sound like a fast car, no wonder they changed the name for the US market
    Sep 2003
    Oakland, MI
    I have noticed the same thing in my '04 WRX. I started to look into it and found that the brake lines run pretty close to the firewall. It wouldn't take much of a vibration for them to start rattling off the firewall. Unfortunately I haven't been able to check this theory but I plan on further isolating the brake lines to see if the noise stops.
    Registered User ryland's Avatar
    Apr 2002
    NY
    Sometimes after I back up, and shift back to first gear and move forward it will go *CLICK* once, like the slack is being removed from the drivetrain somewhere.
    2004 Black WRX Sedan
    Mods = yes
    Sep 2003
    Oakland, MI
    Problem fixed
    I just had my "odd clank sound" fixed, it was the exhaust heat shield around the turbo. It needed to be adjusted and tightened. Looking at it afterwards it seems pretty simple and easy to do if you have a way to get your car up in the air.
    Oct 2002
    Beaverton OR
    Hmmm, that heat sheild that goes around the turbo?
    Could be my problem, although I swear Ive heard it with it off before.
    Im still looking into brake line thing. I haven't heard it since I swapped out my springs (for the second time).
    Sep 2003
    Oakland, MI
    Yup the heat shield around the turbo.
    I still think that the brake lines are routed a little close to the fire wall and/or poorly isolated. I guess there isn't exactly a whole lot of room though...oh well.
