Don't get an autometer boost gauge - Page 2
Results 16 to 30 of 37
This is a discussion on Don't get an autometer boost gauge within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Oh btw, where is a good place to find those Omori guages, I've never heard of them before. Para...
    Registered User paragonwrx's Avatar
    Sep 2003
    Downers Grove, IL
    Para
    Registered User Dream's Avatar
    May 2003
    MN, Twin Cities
    Also, when my car is ideling, my vac is at like 16, I believe it should be at about 19 or 20, so im sure I have a problem with the install.
    Registered User Hot_Dog's Avatar
    Jan 2003
    Albuquerque, NM
    Defi Own3s Joooo!
    2003 WRB Sedan. Mods & Pics
    Quote Originally Posted by scooby-x
    OMG!!! Do you want me on my knees or bent over? I love you
  6. #19
    Feb 2004
    Hickory, NC
    I think it's installed correctly because it reads TOO much boost.
    Mods
    Armed with a rotated Precision 6265 turbo at 35psi and a built 2.5 liter.
  7. #20
    Registered User JRod's Avatar
    Apr 2002
    Harrisonburg, VA
    Did you do the map calibration for the UTEC? I live at sea level so it was not neccessary. What altitude are you at?
    2002 WRX Sedan-Silver
    Turbo XS UTEC Stage IV (VF34)+TMIC, STI RA gears, Exedy clutch/flywheel
  8. #21
    Moderating U! KurleeDaddeeWRX's Avatar
    Mar 2002
    San Jose, CA
    Originally posted by Dream
    Kurlee,
    Did you have any issues with the gauge not reading boost correct?
    Not until the dial fell off. LOL!!!!
    Yes, the boost gauge would never go back to zero after the car was turned off. The dial would always sit a little under zero. And then, on my way to work one morning, I was under boost in a straightaway at WOT, I look down and I see the dail fall off. I was like W T F ??? Needless to say, I will NEVER buy Autometer gauges EVER again for any car I ever drive. And like I wrote above, this happened to 2 seperate Autometer Boost gauges I had, not just one incident.
  9. #22
    Feb 2004
    Hickory, NC
    probably about 800 feet above sea level. How do I calibrate the map on the utec?
    Mods
  10. #23
    Apr 2002
    Harrisonburg, VA
    Just to be clear I'm referring to the map (manifold absolute pressure or something) sensor. Its in the TXS UTEC manual I believe. Should be a couple of threads around too. I dont know if 800 feet is enough to throw it off, maybe.
  11. #24
    Registered User skyjock41's Avatar
    Oct 2003
    PCAN FL
    Ahh the battles of ghetto gauges. i just installed my top of the line jcwhitney boost gauge ($17)
    Ive got the 4eat. Ive seen it peak at 14psi for a second but normally always around 13 then decreases further into the gear. Makes me wonder if i got a boost issue or the gauge is just crap?
    It sits on zero. But went i just start the car and let it idle the needle bounces really fast back and forth between 19 and 20 vac. And when i floor it and boost builds it makes a rattle noise. Whats a good 52MM Mechanical Boost gauge replacement? This thing works but its just wierding me out with its quirks.
  12. #25
    tan
    tan is offline
    Thinking Man's Engine tan's Avatar
    Dec 2001
    Wharton, NJ
    My VDO makes that rattle noise also.
    You need a restrictor in the T-fitting for the line that goes to the boost gauge
    See pic below. It costs $6 for that fitting.
  13. #26
    Registered User Racenut's Avatar
    Dec 2002
    California
    Para
    I got mine from J-Spec Tuning.
    http://j-spectuning.com/omorimain.htm
  14. #27
    Sep 2003
    Downers Grove, IL
    Thanks for the info Racenut.
    Para
  15. #28
    Registered User zoinks's Avatar
    Dec 2003
    Portland, OR
    I have the CF Autometer Boost/Vac gauge as well. I ditched the stock nylon line and fittings and went with 1/8" vac line and brass barbed fittings. My only mods are gutted up and down pipes and I peak around 15 - 15.5 psi and then settles down to 14 - 14.5 psi. In 5th it peaks at 16!!! I don't know whether to believe it or not. I'm definitely getting some better gauges when the cash flow picks up along with many other goodies. The only reason I bought the Autometer is because I got it and the mounting cup for around $35 so I'm not too upset.
  16. #29
    Official ClubWRX arms dealer SOUTHPAW's Avatar
    Feb 2003
    CT
    Hey racenut, Did you get mechanical or elec., and does the needle sit @ 0?
    *1969 Camaro - Kickin' It Old School
    PICS & MODS
    *2005 Corvette C6 - A few APS bolt-ons
    PICS & MODS <- Built by XX Tuning
    *2003 Subaru WRX - 332 AWHP - SOLD
  17. #30
    Dec 2002
    California
    Electric.
    When turned off, the needle drops to 30 whatever measurement that is vacuum... When the key is turned on, but no motor running, the needle sits at zero... start the car and of course it reads whatever boost/vac is sees.
