Boost gauge fittings
Results 1 to 3 of 3
This is a discussion on Boost gauge fittings within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; I'm moving my boost gauge from my steering column to a center pod. I can't get this little part off ...
    Registered User qoncept's Avatar
    Oct 2003
    Montgomery, AL
    I'm moving my boost gauge from my steering column to a center pod. I can't get this little part off the hose so I need to replace it, can anyone tell me where to get it (hopefully in town) ? Thanks!
    Registered User 04blkWRX's Avatar
    Jul 2003
    NNJ
    You can get ferrules at McMaster-Carr but I think it would be easier to just cut the tube back a little and put a new fitting on the end. It only sees pressure to 15psi or so, so an instant-on fitting would be fine. Check your Home Depot (or similar) or a plumbing supply store.
    tan
    tan is offline
    Thinking Man's Engine tan's Avatar
    Dec 2001
    Wharton, NJ
    www.ecstuning.com
    $5
    helps prevent the kink right before the gauge
    I also have an extra plastic fitting lying around also
