I would try and put it underneath the front passenger seat. I think some people have had success by doing that.
This is a discussion on Amplifier installation location within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; I am going to upgrade the speakers all the way around and I want to buy a multi-channel amp for ...
I am going to upgrade the speakers all the way around and I want to buy a multi-channel amp for all 4 but I'm not sure where I can put it. I would like to put it in the trunk but how would I run the speaker wires in the other direction?
- F r a n z
Bucky with teh lime powah!
YepOriginally posted by Th3Franz
I would try and put it underneath the front passenger seat. I think some people have had success by doing that.Both my amps are under the front seats. Sub under the driver side and front components under the passenger side.
James
"Never criticize a man until you've walked a mile in his shoes. That way, if he doesn't like what you have to say, it'll be OK because you'll be a mile away and you'll have his shoes."
Won't that get wet underneath the seat? Do you bolt it to the floor also?
I mounted my amp under the drivers seat on a piece of 3/4 mdf to keep it off the floor. I was just able to sqeeze a 4 channel amp under there and I don't have any heat problems
I have never experienced any water issues, but I haven't tried to tackle any lakes or bogs lately eitherOriginally posted by Stealththx
I use self tapping screws to mount the amps. You can put nylon spacer sleeves around the screws if you want to raise the amps up off the floor board a bit. You can find the spacers at Ace or Home Depot.
James
