At idle you engine is pulling a vacuume ,hence the -.3. As the turbo spools up the engine will go into positive boost, hence the + values. At 6500 are you shifting? It sounds like you hit the clutch causing the BOV to open releasing positive pressure. Just becuase the engine is running does not mean you are in positive manifold pressure.
LinkBack URL
About LinkBacks
