EGT Probe Wire
Results 1 to 4 of 4
This is a discussion on EGT Probe Wire within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Can someone tell me what wire I can use to connect the probe w/ my gauge? I purchased a VDO ...
    Registered User 03WREX's Avatar
    Jun 2003
    SoCaL
    Question EGT Probe Wire
    I purchased a VDO gauge from egauges.com but I've heard that their probes weren't that good so I bought a probe from teamrip.com. I didn't realize that the probe doesn't come w/ enough wire to hook up the gauge.
    Does anyone know the specific type of wire that needs to be used? I'm assuming you can use most wires but will it effect the accuracy?
    Registered User qoncept's Avatar
    Oct 2003
    Montgomery, AL
    As long as you're not using something with too much resistance you shouldn't have a problem, and I doubt unless you used waaaaaay too much wire you'd have too much resistance. Try to get something of the same/similar gauge.
    Registered User Web Foot STi's Avatar
    Jun 2003
    Portland, OR
    You need to use thermocouple wire. Extension grade is a little cheaper for your application. I am guessing that your probe is K, or J type. You will have to match the color code to determine what you need. Here is a site that has EVERYTHING you need for temperature measurement.
    http://www.omega.com/toc_asp/subsect...ok=Temperature
    Standard copper wire will induce an error.
    Cones don't count at Hillclimbs.
    Jun 2003
    SoCaL
    Thanks for the help. I guess I'll just play it safe and order some wire from the place I got the probe. No point in taking a short cut and risk damage to the motor because of a false reading.
