STI Wheel??
Results 1 to 6 of 6
This is a discussion on STI Wheel?? within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; I just recieved my USDM STI steering wheel today in the mail. Ive been searching through the forums all day ...
    Registered User DEADPOOL's Avatar
    Dec 2002
    Boca Raton, FL
    STI Wheel??
    I just recieved my USDM STI steering wheel today in the mail. Ive been searching through the forums all day trying to find out how this gets plugged in, but have had no luck.
    Heres the differences between the STI and the 02 WRX wheel. The STI has 5 wires, while the WRX has 6 wires running to its plug.
    Has anyone done this? Does anyone one know how I can find out what needs to be done??
    Thanks,
    -John
    "Celebrate we will, for life is short but sweet for certain"-DMB
    Liquid - "yes sticky! hes a god now!"
    02 WRX now JDM V8 STI (too many mods for my own good)
    Registered User Liquid's Avatar
    Mar 2004
    Iowa
    Re: STI Wheel??
    Thanks,
    -John
    Im pretty sure the only difference is that the sti doesn't have cruise control so thats y theres only 5.
    Dec 2002
    Boca Raton, FL
    Re: Re: STI Wheel??
    Nope, the USDM STI has cruise control, my wheel has the lever and everything. The JDM STI on the other hand does not have cruise control, which is probably what your thinking of.
    -John
    Registered User BlkWRXWag's Avatar
    Jan 2003
    Trabuco Canyon, CA
    I just did it - check out this thread and see the instructions in one post that I received from Rallispec.
    New Spec C steering wheel installed
    Dec 2002
    Boca Raton, FL
    This should help with some of it, I need to check the color of my wires etc. Only difference is that I have a USDM wheel and you have the JDM wheel, so I need to find a way to wire in the cruise control, hmmmm.
    Thanks,
    -John
    Jan 2003
    Trabuco Canyon, CA
    I wonder if the cruise control unit from your old wheel will just unscrew and and mount in the new wheel - depends on the mounting holes, but unlikely I suspect.
    As far as I remember, the cruise control has three wires which connect to a plug that inserts into the steering column. I would imagine each wire controls the signal depending on which way you move the lever - up/down/pull etc. Hopefully the STi wheel will be set up much the same and you can just splice the new unit to the old harness.
