New Spec C steering wheel installed
Page 1 of 3 123 LastLast
Results 1 to 15 of 36
This is a discussion on New Spec C steering wheel installed within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Well, I never really did like the four-spoke wheel the WRX came with, so I ordered this new wheel from ...
    Registered User BlkWRXWag's Avatar
    Jan 2003
    Trabuco Canyon, CA
    Well, I never really did like the four-spoke wheel the WRX came with, so I ordered this new wheel from Rallispec and installed it last night. Installation was pretty simple thanks to their instructions and the only downside is that you lose the cruise control which I could care less about. After having driven around a bit with the new wheel, all I can say is I love it - it's a slightly smaller diameter than the old wheel and the feel of it is just perfect.
    Moderator MidKnight's Avatar
    Oct 2002
    Bergen, NJ
    Very sweet. I'm a huge fan of 3 spoke wheels.... I wish they made a direct replacement for the wrx that would keep cruise control and airbags...
    '03 WRX
    '01 2.5RS
    MODS | PICS | Dyno
    "Stuff sold by the gram is always going to be more exciting than stuff sold by the pound." - Jeremy Clarkson
    Jan 2003
    Trabuco Canyon, CA
    It keeps the airbag, well replaces it... there is just no hole to put the cruise control lever thru. I guess those handy with the dremel could make one, but since I never use it, I didn't bother.
    Registered User PKer's Avatar
    at work
    Looks great! But I still don't want a quick feel no matter how little you charge.
    I will touch the steering wheel though.
    Jan 2003
    Trabuco Canyon, CA
    Come on Seb - you know you want one!!
    May 2003
    Wisconsin
    How much did it cost if you don't mind my asking?
    - F r a n z
    Bucky with teh lime powah!
    Jan 2003
    Trabuco Canyon, CA
    $325
    May 2003
    Wisconsin
    Originally posted by BlkWRXWag
    $325
    Wow, and it includes the airbag? That's not bad.
    - F r a n z
    Jan 2003
    Trabuco Canyon, CA
    Yes - that includes everything.
    May 2003
    Wisconsin
    How was the install? I've never swapped steering wheels on a car before.
    - F r a n z
    Jan 2003
    Trabuco Canyon, CA
    Here are the instructions I got from Rallispec - it really was pretty simple...
    First off....disable the airbag system by removing the two fuses for the airbag at the instrument panel fuse box.
    We have found that the actual wire colors on the harness at the airbag itself varies from year to year. The only way to be sure you are connecting the correct wire colors is to verify the position of the wires at the lower connector at the base of the steering column. To access this lower connector requires removing the kick panel under the steering column. The lower connector is identical for both the WRX and the STi airbag roll connector....it is only the upper connector at the airbag itself that is different. To install, cut the upper connector off of the supplied STi roll connector harness and install in place of the existing WRX connector. There are only two wires so compare the relative positions of the wire colors at the lower airbag connector and ensure that you are connecting them in the correct position. Solder the wires to ensure a good connection and use shrink tubing to insulate each individual wire. Overwrap the connections with electrical tape.
    According to the WRX roll connector we have here....there is a yellow/blue and yellow/black wire on the WRX harness. We found that the STi's yellow/black wire connected to the yellow/blue wire and the yellow/red wire to the yellow/black wire on the WRX. PLEASE NOTE THAT YOUR COLORS MAY VARY SO ALWAYS DOUBLE CHECK THE RELATIVE POSITIONS OF THE WIRE COLORS AT THE BASE CONNECTOR AT THE BASE OF THE STEERING COLUMN.
    The horn connector will also require modification.....the green/red wire on the WRX should be attached to the green/red wire coming off the airbag for the horn.
    May 2003
    Wisconsin
    Ok. If I saw it in person it would probably make more sense. If I got the steering wheel I think I'd give my skills with the dremel a try to keep cruise control as well.
    - F r a n z
    Jan 2003
    Trabuco Canyon, CA
    Yeah - it is easier when you have a visual on all the wires. Essentially, you just have to cut and solder three wires. Rallispec claims they can do the swap in 15 minutes, but it took us closer to an hour. The problem with the cruise control is not just the cutting of the hole, but you have to figure out a way to stabilsize the internal mechanism as it is bolted into the inside of the wheel. I'm sure the new wheel does not have the appropriate mounting holes.
    May 2003
    Wisconsin
    Ohhh Ok. Hm...
    - F r a n z
    Jan 2003
    Trabuco Canyon, CA
    Here's a pic of the cruise control unit in the old wheel...
