Results 1 to 4 of 4
This is a discussion on Installing air fuel ratio guage within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; I just perchased the autometer sport comp air fuel ratio and it does come with directions, but im sort of ...
    Sep 2003
    Las Vegas, NV
    Arrow Installing air fuel ratio guage
    I just perchased the autometer sport comp air fuel ratio and it does come with directions, but im sort of new with all this wiring stuff and i want to do it right. Can anyone familiar with installing these on our rexes give me tips, advice, or even instructions. Thanks.
    Dec 2003
    Rancho Cucamonga, Ca.
    I got an afr gauge as well to install on my mother in laws wrx. I hooked up the signal wire to the white wire on the rear o2 sensor. I wasn't sure if this was the correct connection because the only reading I got was very faint. It was the furthest red on the lean side, and hardly showed up at all.
    I got the information off of this site (for the white wire hookup) and I just wanted to come back and make sure I did this correctly. (Figured I'd just add on to this thread)
    Anyone else make this hookup differently. Thanks in advance.
    Oct 2004
    Quote Originally Posted by stealthmode
    hey your not alone the same thing happened to me. i put it on the blue wire and it reads but not correctly it reads real slow , what gives.
    Registered User boosted scoob's Avatar
    Aug 2004
    Robins AFB, GA
    I have hooked one up too and same thing happens. Lean to stoich, but never in the rich. And it does not move to and fro like it's supposed to. Then I learned that the rear o2 sensor is not meant to read the full 0-1V because the computer does not need it to read actual air/fuel. That's what the wideband one is for in the uppipe (or header, I forget). Anyways, that rear o2 is only supposed to measure after-cat mixture. I am just going to put in another 02 sesor from like a Mustang GT in an extra bung I have on my DP.
    02 WRX - XS Power header/UP/TBE, XS Power FMIC, MBC@15psi, Ported TD04L, Perrin shortram, Alum Radiator - 13.35@101
    05 Mini Cooper S - Bone stock
    95 Mustang GT conv. (Work In Progress) - BBK LT headers & h-pipe, dumped Flowmasters, Kirban AFPR, BBK subframe braces, 6-point rollcage, FMS springs, 70/30 struts, 50/50 shocks, K&N intake
