200 W amp too much for STI alternator?
Results 1 to 9 of 9
This is a discussion on 200 W amp too much for STI alternator? within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Anyone running a 100 W x 2 into 4 ohm amp setup on a STI? Any problems with it drawing ...
    SRR
    SRR is offline
    Registered User SRR's Avatar
    May 2003
    Denver, CO
    Anyone running a 100 W x 2 into 4 ohm amp setup on a STI? Any problems with it drawing too much current from the alternator?
    The manual on mine says it will draw <20A music avg at 4ohms and <35A with signwave 4ohms a channel. It uses a 30A fuse.
    Thanks
    Scott
    Registered User wonderspark's Avatar
    Aug 2003
    Lakewood, CO
    I've been running an 800W amp with no problems.
    Registered User Vendeta2K's Avatar
    Aug 2003
    Montana
    shouldn't cause a problem
    vendeta2k
    Accessport + COBB SF Intake = BEST MOD EVAR!!!!!
    SRR
    SRR is offline
    May 2003
    Denver, CO
    Thanks
    May 2003
    Wisconsin
    Only if your amp is really inefficient. If you don't crank it up loud, don't worry at all. But if it has an efficiency of like 20% and you turn it up, then expect some hefty current draw. But you probably don't have to worry.
    - F r a n z
    Bucky with teh lime powah!
    Registered User happasaiyan's Avatar
    Nov 2002
    Rolling Meadows, IL
    im running a 5 channel with 1200w no prob.
    '04 PSM STi - modded (sr50+the works)
    '05 JGM RSX Type-S - stock
    May 2003
    Wisconsin
    Once I get my car we'll see how it handles a total of just under 2000 watts RMS.
    - F r a n z
    Registered User Tony Soprano's Avatar
    Vancouver USA
    I am running an RF 600w and a JBL1200w
    No probs yet
    May 2003
    Wisconsin
    No probs yet
    How often do you crank it up all the way? I like to meter my system to see how loud I hit. In my last car, only 135 dB on a TermLab, but once I build a new box, I'm thinking 140 is possible with just two 10's.
    - F r a n z
