Where Do You Route Your Boost Guage Hose???
Results 1 to 15 of 16
This is a discussion on Where Do You Route Your Boost Guage Hose??? within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; I have an Autometer mechanical boost guage that I am trying to install, and want to know where others have ...
    Registered User Rubby_Subby_R1's Avatar
    Jan 2004
    EngleHood, CO
    I have an Autometer mechanical boost guage that I am trying to install, and want to know where others have routed the 1/8" nylon tubing through the firewall. I found an easily accesible area next to the A/C drain pipe, but I think it's a little far to route the hose from the cluster back to the blow off valve. Any suggestions are greatly appreciated!!
    Registered User ebr0t's Avatar
    Aug 2002
    U of Central Florida (Orlando)
    Re: Where Do You Route Your Boost Guage Hose???
    there are little holes coverd by black plugs behind the pedals to wire guages through. That is your best bet.
    Quote Originally Posted by DTR rex
    Peter North > *
    Jan 2004
    EngleHood, CO
    Thanks
    Thanks ebr0t for the response. I will take a look under there later tonight.
    Jul 2003
    KC, MO
    unscrew the two nuts of the windshield washer container and move it out the way for super super easy access.
    04 WRX Black no options!
    Helix up/downpipe, HKS catback & Bov, autometer gauges and MRT shortshifter, Bronze Rota SDRs, UTEC, tein SS coilovers, HKS type1 turbo timer, 6000K HIDs, JDM spec C front/rear lips, 20% tint
    to be installed: Mines Spoiler
    Registered User Wade-0's Avatar
    Dec 2002
    Southern Orygun
    I found a nice opening behind the intercooler, so the hose comes into the car behind the stereo, which is perfect if you have your gauge in that area. I think the most important thing is to use the route that gives you the shortest length of hose depending on where your gauge is going to be.
    Registered User Toophless's Avatar
    Feb 2004
    Winston Salem, NC.
    Subaru runs their's through a hole over the gas pedal. It's plugged with a pretty nice sized rubber grommet. I've run three hoses through mine no problem. It's very easy to get to if you pull the TMIC.
    Move.
    Jul 2003
    KC, MO
    even easier if you just do what i suggested.
    Jan 2004
    EngleHood, CO
    Angry Only 8lbs of boost now
    Thank you everyone for your suggestions. It is a lot easier to thread the tube through the firewall with the IC removed. I ended up using a large plugged hole just next to the master cylinder. I'm not sure I understand how pulling the washer resivor gives you easy access to the cab of the car. Please explain.
    I do have one other problem though. I am only pushing 8lbs of boost in all gears. I know that the stock ECU limits boost to around 8 in 1st and 2nd, but shouldn't 3rd on up be closer to 14? I tee'd off of the 1/4" hose going into the blow off valve. Do I need to reset the ECU? Any suggestions.
    ERIC
    Dec 2002
    Southern Orygun
    Sounds like you're running at wastegate boost. Are you the original owner of this car? Have you messed with the boost control setup?
    Jan 2004
    EngleHood, CO
    Yes, I am the original owner of the car, and no I have not done anything to play with boost control settings. The car is less than a year old with just over 10k miles on it. The engine related mods I have are:
    Removed Silincer
    Grounding Mod
    Catless Up-Pipe
    HKS Cat Back Exhaust
    The car pulls very hard on my butt dyno, so I can't imagine that I'm only running half the boost possible. I am thinking that I will take in to a shop and see if they have another guage they can throw on to verify that the guage is working properly.
    Dec 2002
    Southern Orygun
    Typically you will see around 9psi max if you hooked up the vacuum lines (T that connects the turbo to the FBC and the wastegate solenoid) backwards. Did you remove any of these vacuum hoses during the uppipe installation?
    Jan 2004
    EngleHood, CO
    I don't recall removing any vacuum lines when I did the up-pipe install, but that was last July. I will have to take a closer look later tonight when I get home.
    Am I correct in tee'ing off of the blow off valve line, or is the hose supposed to be tee'd from somewhere else like the wastegate solenoid?
    Dec 2002
    Southern Orygun
    That's the usual spot, and also where the factory gauge is connected.
    Jan 2004
    EngleHood, CO
    Thumbs up Working Good!!!!
    I finally got everything sorted out. Thanks for the replys on the routing and boost issues. I figured out that my 3/16" mod was robbing me of 5 psi of boost I replaced that with the factory fitting and am now running at around 13 psi in 3rd and fourth. Thanks again for everyone's help. I post pictures if I can get them downloaded.
    Registered User ProdriveREX's Avatar
    Jan 2004
    Seattle WA
    3/16
    so....3/16 mod is mod that TAKES YOUR BOOST AWAY??? what is the point for it then?
