help on climate control & air bag.
Results 1 to 6 of 6
This is a discussion on help on climate control & air bag. within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; 1. climate control. I don't know when it happened but something fell through the heater/AC outlet on center console. I ...
    Oct 2002
    1. climate control.
    I don't know when it happened but something fell through the heater/AC outlet on center console. I couldn't turn the climate control knob. I guess that "something" is stuck. how do I get that out?? I went to the dealer and they told me it would cost me 800 + labor.
    2. air bag sign.
    the yellow cable under our seat, which suppposed to be related to air bag, is completely disconnected. it's causing airbag light to come on. I went to the dealer and they estimated about 1500 for air bag cable and module + 500 for diagnos + labor. Do I really need those parts to be replaced? They said I can't just slice and connect that cable again becaise it'll create more resistance. Is that true??
    thnx for your help.
    Registered User wonderspark's Avatar
    Aug 2003
    Lakewood, CO
    2. Airbag - I can help with this one since I just fixed mine up myself. Get a 3.3 ohm 1/4 watt resistor, clip the wires so they are just long enough to jam all the way into the yellow wiring harness and fit in snugly, then tape the ends so they don't come out. No airbag light, and airbag system works normally, minus the seat's airbags of course. The resistors are about a dime each, much cheaper than any other alternative.
    I got JDM STi seats, which are much tighter but have no airbags, so I had to do this to both seat connections. Works like a champ!
    Registered User Evil Imports's Avatar
    Oct 2002
    AZ
    is this the same resistance for the steering wheel airbag???
    Aug 2003
    Lakewood, CO
    Think so, but I admit I don't know 100%. I have to assume so, since it is the same system.
    Registered User Family Guy's Avatar
    Jul 2003
    Memphis TN
    Quote Originally Posted by wonderspark
    I tried this and still have an airbag light on my car, any ideas?
    Now: 04 WRB STi (stock)
    Jul 2003
    Memphis TN
    Update: I was using 3.3k ohm resistors which will not work. Using the 3.3 ohm works fine.
