Need DRL HELP now!! Please...
Results 1 to 14 of 14
This is a discussion on Need DRL HELP now!! Please... within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; My request: - where is the brake light trigger/adjustment that turns on the DRL when you release the hand brake...I ...
    Registered User SWRX's Avatar
    Jan 2004
    SoCal
    My request:
    - where is the brake light trigger/adjustment that turns on the DRL when you release the hand brake...I need to know ASAP..
    My brake light is consistantly on, even when i put the hand brake down.
    My reason:
    A shop helped me install HIDs and adjusted something in the hand brake area that made the brake light on all the time to trick the car into thinking that the hand brake is on, so that the DRL would not turn on. I guess he did this because the DRL does not have enough power to power the HID, and thus leads to flickering of the HIDs...
    the shop wanted to charge me to have them TRY to fix it...damn!!
    ** I disconnected the DRL socket that's located under the glove box...
    now I just need to get that brake light off...
    I can take a picture and post it if someone needs it to show me..
    Thanks so much
    Jan 2004
    SoCal
    ttt...please
    Jan 2004
    SoCal
    I'll take any info...perhaps something about what that sensor might look like?
    the only adjustment that I see is one with 2 nuts that lead to a cable (i'm assuming it the hand brake cable), should I adjust it to make the brake light disappear when I put the hand brake down?
    Jan 2004
    SoCal
    ttt
    Registered User gh0st1y's Avatar
    Feb 2003
    lake worth, fl usa
    hey, i dont think i really can help u but i just wanted to let u know that that happened to me too. i took the drl unit off and the ebrake indicator wont turn off even with the ebrake down. all i did is plug the drl unit back on. i asked this ? like a month ago and noone replied. i pretty much replied on my own thread too.
    peace
    "u would never realize something unless u did the opposite"
    --me
    Jan 2004
    SoCal
    peace
    the idiot that installed my HID just messed with the drl adjustment in the e-brake console and freaking TAPED my brake light indicater in the dash!!! I was pissed... anyways....
    you said you "took the drl unit off"... and the brake light is still on even with e-brake down..hmm...sounds like some sensor (possibly in the e-brake console) is reading that the e-brake is up... i don't know... but i'll ask my installer where that adjustment is...
    Well...my problem was solved when I got a paging alarm system and the installer fixed it... unfortunatly, i was not there when he did it, but I will go back to see him sometime this week...i'll keep you posted!
    Jan 2004
    SoCal
    my installer was off today...i'll keep ya posted!
    Registered User 20wrx02's Avatar
    Oct 2002
    South East Mass
    in the glove box remove the connector to take off DRL for HIDs
    do a search
    as for ur brake light -- he F**ked it up
    goodluck
    Jan 2004
    SoCal
    as i mentioned earlier...my installer took care of the brake light problem...i just wasn't there to see him adjust something in the e-brake console. My car is working perfect now...i might go see him later this week..i'll keep ya posted about how he "fixed/adjusted" the brake light sensor
    Registered User djrez4's Avatar
    Colorado
    There's a pink wire attached to the E-brake that tells the car when the brake is engaged. Your original installer probably moved the wire so the contacts were always touching. That would keep the DRLs from turning on. It's also about the stupidest method I can think of. I'd stop taking your car to that installer.
    Deliberating enclaves of like-minded people are often a breeding ground for extreme movements - Cass Sunstein
    Jan 2004
    SoCal
    that guy screwed up big-time..i mean...i'm planning on throwing more money on this awesome car...but it ain't going to that fool!...he was a friend of mine, but i didn't know he would pull that one on me!!!
    well...people that go to him never goes back for anything because he always takes shortcuts...i mean..damn...wtf?...
    anyways...i think you were right about that pink wire thing...how to move it so it functions normally...i don't know... but good luck with getting it back to normal
    Registered User Family Guy's Avatar
    Jul 2003
    Memphis TN
    Any updates?
    Now: 04 WRB STi (stock)
    Registered User wrxinfx's Avatar
    Mar 2004
    house
    1. shoot your installer
    2. search this forum for hid installs and it'll guide you through proper installs. Then copy and print the thing and mail it to your installer.
    3. Give him a hard time for a shady install. Maybe he'll give you a refund or a discount or something.
    4. Correct the mistakes he made or your expensive hid's are gonna fry.
    5. Skip #1 and do #2 first. Then if all fails....... Shoot him
    Jul 2003
    Memphis TN
    So what happened to get the brake light out?
