GReddy 52mm Boostgauge install guide.
Results 1 to 15 of 26
This is a discussion on GReddy 52mm Boostgauge install guide. within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Today I installed my GReddy electronic boost gauge. It tooke soem time to figure it out but I got it. ...
    Registered User PolarisSnT's Avatar
    Aug 2002
    Staten Island, NY
    Steps-
    1. Disconnect Battery first. Remove lower dash, and clock pod. The clock pod is pretty tough to get out but use a flathead screwdriver to pop up the back and pull straight up with your hands for the front. Its tough.
    2. Go under the hood and locate your BOV return line and cut it in a spot that a inline T connector will fit. The one supplied in the kit will not work. I went to the hardware store and bought a 1/4"x1/4"x1/8" T. I got 2 but becareful the 1/8" snaps real easy so dont put any pressure on it.
    3. Work the 2 1/4" ends into the BOV return line.
    4. Take the supplied sending unit and mount it in a suitable location. I choose to put mine on the battery holder bolt closest to the washer bottle.
    5. Go under your dash and locate and remove the rubber grommet, above the clutch pedal.
    6. Go back under the hood and drop the wire down near the grommet. Then go back into the car with a metal coat hanger(straightened with a hook on one end) and pull the wire through.
    7. Run the wire to approximately where the gauge would go.
    8. Take the supplied power harness with the 4 wires coming out of it and be prepared to add extra wire. I just added about 2 feet, approx, of the same gauge wire, all red, to the ends of each and marked them carefully.
    9. Disconnect clock and put aside. Unwrap the electrical tape from the outside of the harness that goes to the clock.
    10. You will see 4 wires. 1 Blue, 1 yellow, 1 pink, and 1 black.
    11. On the harness wires are 1 Red. 1 Orange, 1 whitem and 1 black.
    12. Connect, using the supplied splices, the Red wire to the blue wire, the yellow wire to the orange wire, the pink to the white wire, and the black to the black wire.
    13. The Red and blue connection is for your power, the yellow and orange is for the ignition,, the pink and white is for illumination, and the black and black is for ground.
    14. Finally mount your gauge, run your wires, hide them, put back grommet, and put back your lower dash, and clock.
    Thats it your done. It was easy once you figure out what wires go where but other than that it wasnt bad. Ill post pics tomorrow when its light out.
    Dan- 2004 PSM 5spd
    "Days get shorter, nights get longer, snow gets deeper, life gets better."
    Aug 2002
    Staten Island, NY
    Gauge mounting. My bracket did not come yet so in the time beaing i made one out of a piece of 1x5 and used my dremel to make it round. Painted it black but some doublem stick tae on it and it works good for now.
    Dan- 2004 PSM 5spd
    Aug 2002
    Staten Island, NY
    Closer Gauge.
    Dan- 2004 PSM 5spd
    Aug 2002
    Staten Island, NY
    Grommet
    Dan- 2004 PSM 5spd
    Aug 2002
    Staten Island, NY
    1/4"x1/4"x1/8" T spliced into BOV return line.
    Dan- 2004 PSM 5spd
    Aug 2002
    Staten Island, NY
    Sendor unit mounting spot.
    Dan- 2004 PSM 5spd
    Aug 2002
    Staten Island, NY
    Engine overview.
    Dan- 2004 PSM 5spd
    Nov 2003
    That is awsome jsut what i was looking for but the guage pod is fugly, i want one that is flush with the rest of the car
    J-H
    J-H is offline
    Registered User J-H's Avatar
    Jun 2003
    San Diego
    I have mine on the left vent outlet. Fits perfeclty...
    JH
    OCD
    OCD is offline
    Aug 2003
    NY
    thats the electronic boost gauge right?
    Registered User ryland's Avatar
    Apr 2002
    NY
    Yeah, I would assume so, since there is a sending unit.
    2004 Black WRX Sedan
    Mods = yes
    Aug 2002
    Staten Island, NY
    Yep thats the electrical one. As for the pod, its only temporary till mine gets here. There was a problem with shipping.
    Dan- 2004 PSM 5spd
    Mar 2002
    Tokyo, Japan
    Good install/Review, Dan.
    "I don't think he knows how to give up. His mind and machine are racing as one." -Takahashi Ryosuke
    Apr 2002
    NY
    What does the red button do?
    Mods = yes
    Registered User bunni's Avatar
    Sep 2003
    Los Angeles
    night shots?
