Autometer Boost Gauge Problem
Results 1 to 15 of 15
This is a discussion on Autometer Boost Gauge Problem within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; Just installed the Autometer boost gauge. Everything was fine. engine at off is at 0psi idle -14psi at wide open ...
    Registered User skoobywrx's Avatar
    Nov 2002
    Seattle
    idle -14psi
    at wide open its about 8-9 psi
    wheres my other 5?
    my car feels fine before and after the gauge install
    mods,
    Turbo XS TH BOV
    K&N Typhoon(i know i know, but hey, it was free for a mock from K&N)
    axle back
    I ver read and searched for some items.......but no clear answer
    would the nylon tube connection have a problem? kinks in the tube? Im gonna switch to all rubber tubes tonight....any other things you can think of?
    Registered User Ludecrous's Avatar
    May 2003
    manchester
    check the tubes, the tee fittings and adapters, at idle you should not be reading 14psi, you should be reading Vac not boost.
    Registered User 04blkWRX's Avatar
    Jul 2003
    NNJ
    That looks like a negative 14
    Nov 2002
    Seattle
    that should 15vac, mmhg
    Jan 2004
    WI
    actually it would be in in/hg inches if mercury
    Integra LS TURBO for sale PM me
    Registered User dcraw6782's Avatar
    Jun 2002
    Charleston
    check your boost line and fittings - i had the same problem, and found a leaky fitting under the dash - once i replaced that - no problem.
    "Let me never be accused of standing between a Charlestonian and his drink" - J. Kuhn
    Registered User Rubby_Subby_R1's Avatar
    Jan 2004
    EngleHood, CO
    3/16" Mod???
    Did you do the 3/16" Mod???? If so, that is probably what is causing your low boost. I just had the exact same problem with an Autometer guage. I couldn't get more that 7-8 psi in any gear. I triple checked the line for kinks and leaks and found none. I thought about the 3/16" mod and decided to put the factory fitting back in to see if that was the cause. Sure enough; now I am pulling about 13 psi in 3rd and 4th.
    Nov 2002
    Seattle
    thanks guys, for all your help.....
    found the problem........
    return the car to stock hoses, and there was still a prob. found out that my boost solenoid was out. so right now im using a boost controller, turned it to about stock boost, will replace the solenoid.!!!
    thanks
    Mar 2004
    Fairfax, VA
    I've got a similar problem...
    Autometer boost gauge is reading 0 at idle, ~25psi at WOT.... I'm guessing for some reason I'm 14psi too high (that would put max boost somewhere in the realm of stock). I really back off the throttle when I see that guage hit 25.
    Shouldn't the gauge read about -14psi at idle??
    Jul 2003
    NNJ
    UGotBoost: Is your gauge electric? If so, its not calibrating properly at startup so it thinks your idle pressure is 0 psi and it goes up from there. You need to power it off a circuit that remains powered during cranking.
    Official ClubWRX arms dealer SOUTHPAW's Avatar
    Feb 2003
    CT
    What the he11 is the 3/16" mod???
    *1969 Camaro - Kickin' It Old School
    PICS & MODS
    *2005 Corvette C6 - A few APS bolt-ons
    PICS & MODS <- Built by XX Tuning
    *2003 Subaru WRX - 332 AWHP - SOLD
    Registered User Dream's Avatar
    May 2003
    MN, Twin Cities
    Feb 2003
    CT
    Got it.
    PICS & MODS
    Mar 2004
    Fairfax, VA
    That sounds like it's my problem; I've got the gauges powered off of the radio's power, which is cut during cranking.
    Where's a circuit I could tap into that remains powered? Also, I'll only need to power my red (+voltage) wire off of it... a ground's a ground, right?
    Jul 2003
    NNJ
    Yes, a ground is a ground.
    For power, I tapped the fuse to the lower left of the fuse panel. I put a 1A fuse on the wire to my gauge as well, so its a more convenient spot if I need to change it.
