Tried to replace speakers in the wrx and failed
Results 1 to 12 of 12
This is a discussion on Tried to replace speakers in the wrx and failed within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; I want to replace the speakers in my 02 wrx. I went to best buy and they recommended 5.5 inch ...
    Nov 2003
    I want to replace the speakers in my 02 wrx. I went to best buy and they recommended 5.5 inch speakers for front and rear. Brought the speakers to get installed and they said they wouldn't fit something about the fronts hitting the window and the rears being too large. What size speakers should I buy to replace front and rear? is it even worth it I want the sound quality to go up. thanks for any help.
    Registered User WRXout's Avatar
    Dec 2003
    Houston
    just get what you had as your stock sizes but get like better quality like sony...
    Fadi....
    • 04' WRX, Stage 4 with fmic R.I.P
    • 05' WRX STI, 325whp 346wtq @17psi
    MODS
    Quote Originally Posted by Trailboss
    Enough of the bloody titties show.
    May 2003
    by all means, please do not get sony. they suck. first off, front speakers on the wrx to my understanding r 6.5" and the rears are 4". since the mounting depth is an issue just make some spacers out of 3/4" MDF for the front and the rear. with the spacers, the 5.5 (i think you meant 5 1/4" but i may be wrong) speakers should fit in the back and in the front. personally, i would get some 6.5" speakers for the front.
    Registered User Wade-0's Avatar
    Dec 2002
    Southern Orygun
    Check the Cockpit and Cabin forum. This topic has already been beaten to death, there's more than enough reading material in there for you.
    Registered User Nck1285's Avatar
    Dec 2003
    Chicago, IL
    Made your mistake by going to best buy for speakers/advice - From what I know, they do everything from a template. :\
    2004 Subaru Impreza 2.5RS
    Platinum Silver Metalic
    DOB: 12/3/2003
    Q RayfieldsWRX's Avatar
    Oct 2002
    The Old Folks Home
    There's a fairly serious limit on depth with the fronts. I had to space out some even to get my Infinity References to fit.
    --Ray
    "Bro ima get Bimota BB3 because expert. My parents have 911 turbo but awd won't let me launch, ima get 962 twin turbo Group C bro." -- SD_GR
    2013 Subaru BRZ Limited
    2002 Subaru WRX Bugeyebrid Wagon -- SOLD
    2002 Subaru WRX Sedan -- SOLD
    Registered User Silva_Wagon's Avatar
    Jul 2003
    Farmington, CT / Boston, MA
    I've heard good things about iaperformance.com they make spacers for speakers...I'm planning on using them when I install a new system...still in the planning stages.
    4 tires...a motor...a couple doors I think...I'd have to check.
    Registered User tubbytreats's Avatar
    May 2003
    For those who didn't want to look this stuff up:
    STOCK:
    Fronts are 5.25"
    Rears are 4"
    With some MDF board and spacers, you can get:
    Fronts 6.5"
    Rear 5.25"
    I have Kenwood 3-way speakers in my WRX and have no problems. (click the link in my sig - that's why it's there!) They're perfect depth-wise, but the extra tweeter setup makes the middle of the cone touch the black plastic mesh cover for the speakers.
    I'd suggest something like Infinity Kappa's that are not very deep. SOOOO many WRX'ers have them in their cars and love em!
    PM me for help.
    2002 WRX Mods:
    AP Stage2/93, ScoobySport Up, Dp, & Muffler, SS AutoChrome TMIC, Hawker PC680T Battery, Injen CAI, ACT Stage2 Clutch, Gruppe-S 13.8lb Flywheel, Mobil1 and Redline oil, NGK BKR7EIX plugs, Goodridge SS Lines, Motul RBF600, Hawk HPS pads, 35% 3M tint, Koji Headlight Mod, SilverStar Bulbs, Blaupunkt MP3000 headunit, Infinity BassLink Sub, Kenwood KFC-1689ie speakers (6.5"F / 5.25"R), Rota Downshift (Black), Yokohama AVS ES100 (225/45/17)
    Registered User Strider's Avatar
    Jun 2003
    New Hampshire
    I upgraded the speakers in the front with slightly bigger speakers, and then made my own spacers. It was pretty do-it-yourself and it only costs about .45 cents.
    I had some plastic laying around that I fit to the speakers. I then used some 2" bolts and three nuts on each bolt. Cut the plastic to match up with the existing speaker holes, and your off.
    Attach the plastic to the speaker and bolt it on, then use the legth of the bolts as your spacer...and if this makes any sense to you, you need to get out more.
    The window goes up and down and does not hit the speaker!!!
    Not all who wander are lost
    Nov 2003
    I work at best buy so I get a huge discount that's why I went there. They don't have infinity. The ones I was interested in were pioneer and kenwood.
    Registered User bunni's Avatar
    Sep 2003
    Los Angeles
    6.5 front, 5.25 rear, get the spacers from www.iaperformance.com.
    I just picked up some Infinitys and the spacers... I'll be installing them once the speakers arrive... the spacers look like they'll be a perfect fit...
    May 2003
    Those look like the EXACT same things I bought back in March 03. They are high quality and work great I'll let you all know!
    2002 WRX Mods:
