Amplifer help
Results 1 to 12 of 12
This is a discussion on Amplifer help within the Interior Mods forums, part of the Tech & Modifying & General Repairs category; I have a MA audio 1000XL 10" sub and here are its specs: 500W Rms 1000W Max Dual 4-Ohm Voice ...
    Registered User REX5280's Avatar
    Dec 2003
    Strasburg, Colorado
    Amplifer help
    500W Rms
    1000W Max
    Dual 4-Ohm Voice Coils
    240oz. Double Stacked Magnets
    Mounting Depth: 5.8"
    Mounting Diameter: 9.3”
    Optimum Vented Box: 1.75 Cu/Ft
    Round Port Diameter: (2) 4”
    Square Port Area: 25 Sq/In
    Port Length: 11”
    Optimum Sealed Box: 0.5 – 1 Cu/Ft
    I am trying to find an amp that will push it hard but I dont know how to figure what ohm load will be put on the amp. Here are the amps I am looking at:
    http://www.maaudio.com/productcatalog.cfm?class=611
    I have the 297 and its ok but it doesnt push the sub to anywhere near it potential. Any help would be greatly appreciated.
    May 2003
    Wisconsin
    Well, I assume you want to wire the sub at 2-ohm then? I generally like to have some overhead for powering sub-woofers, so I say get an amp that's maybe 600 W RMS at 2 ohm MONO. I'm not sure all of those MA amps are stable at 2 ohm MONO.
    - F r a n z
    Bucky with teh lime powah!
    Dec 2003
    Strasburg, Colorado
    is minimum load and stable the same thing? Most of the amps say they are 4 ohm minimum load in MONO.
    May 2003
    Wisconsin
    Well, usually the loader impedance, the more power the amp is pushing. For example, the amp I have is about 1000W at 4 ohms, but if you wire it at 1 ohm it's close to 2000W or so. If an amp is stable at 4-ohm, it might not be stable at 2 or 1 ohm.
    - F r a n z
    Registered User platano's Avatar
    Feb 2003
    Miami
    Reading the specs for the 267, doesn't look like you can do 2ohm mono on that bad boy. 4ohm mono is the way to go. Your amp should be ok (not optimal, but it should move them pretty good).
    What's the size of your box? You want to make sure you got optimal size to get best sound.
    The HK-401SX (high current series) should work for your speaker too.
    Dec 2003
    Strasburg, Colorado
    So if I wire both voice coils to the amp would that make a 2 ohm load? I get so confused with this stuff. And then on mine how would I wire it at 4ohm MONO? Thanks for help.
    Feb 2003
    Miami
    If you connect the leads in parallel, the impedance will be 2ohm,
    if you do a serial connection, you'll get 8ohms. I would assume you want to go across only one set of leads only for 4ohms. (Im guessing on the last one because I'm not sure is MAAudio does something different with their coils/connections).
    Dec 2003
    Strasburg, Colorado
    If you would do me a favor look at the HK1997 it is rated at 1200w @ 2ohms, 600w @ 4 ohms and so if I ran it at 8 ohms would it put out 300w?
    May 2003
    Wisconsin
    I would wire 2-ohm instead of 8-ohm.. Otherwise you could try 2-ohm with an amp and see how well it works. If the amp gets too warm, then you'll have to try something else. If you had 2 subs, you could wire them at 4 ohm. If you got the amp you mentioned, it would most likely be a really expensive amp to only use for a fraction of the power in my opinion.
    - F r a n z
    Dec 2003
    Strasburg, Colorado
    I had the amp I have now wired at 2 ohms in my last car and it would cut out on big bass hits. I have a cap now so I am hoping that will help with that. I can get the one I am talking about for less than 200 so it wouldnt be too bad. I just dont know what to do.
    May 2003
    Wisconsin
    Yeah, caps are kind of a mixed bag. I have a 1-farad capacitor in my current car, but mostly because I do blurps for competitions and stuff. Are the ratings on that amp RMS or peak? Hopefully they are RMS..
    Oh, and perhaps look at the HK-897 if the price is right. You could wire your sub at 2 ohm, and then only use one of the channels from the amp, but not bridging it to MONO. That way you would get 500W at 2 ohm and it should be fine at that.
    - F r a n z
    Dec 2003
    Strasburg, Colorado
    I can get the 897 for like 180 so I will look into that. Thanks for all the help. I had the 297 wired at 2ohms on the one channel and it was fine.
